Warped cylinder heads
davep84
Year and Model: 2000 S70 GLT
Has thanked: 1 time
Been thanked: 9 times
Post by davep84 »
Hi Everyone,
I'm working on a 98 V70 GLT that I purchased recently. It was pressurizing the cooling system so I pulled the head. The machine shop says it was warped beyond repair. After that I bought another used one and now the shop says it's worse than the original one. Any tips on finding a good one?
melmaclifeform
Year and Model: 2000 S70 GLT SE
Has thanked: 2 times
Been thanked: 7 times
Post by melmaclifeform »
Have you considered just taking the original head to a machine shop and having it rebuilt?
2000 S70 GLT SE
1997 Volvo 850 T5
2011 Volkswagen Jetta SE
1999 Mazda Miata
kklepack
Year and Model: 2016 XC60
Has thanked: 12 times
Been thanked: 5 times
Post by kklepack »
I would also try another shop for second opinion.
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
Clearwater on eBay has a remanufactured heads.
Volvo 850 Inline 5 Cylinder Head Cast # 1001716 REBUILT 1997
Volvo 850 2.4 DOHC 5Cyl Cylinder Head Casting #1001525 ONLY 92-97 REBUILT
This is from an individual only $442.00 Remanufactured and 20 new lifters.
There are more there keep digging.
Active
Past
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
davep84 wrote: 01 May 2020, 15:52 Hi Everyone,
Pull one yourself from wrecked junkyard car is probably your best bet. You'll want to rebuild it as you suggested, but it will be straight and therefore trouble free when you are done. HPT or LPT have the same head, non-turbo head has different valves.
I wouldn't trust a head from Clearwater or any high-volume rebuilder, the machine work is probably great but it is fair to assume they are putting in cheap valve stem seals. Valve stem seals are an achilles heel on these engines. Only use Volvo branded valve stem seals on a rebuild, cost is about $80 for a full set from Volvo. Similarly, I wouldn't trust any eBay head unless I could get confirmation they used Volvo branded valve stem seals.
davep84
Has thanked: 1 time
Post by davep84 »
Ok. I'll keep checking. Ones from 99 and up won't work right? Thanks for all of the replies!
RickHaleParker
davep84 wrote: 02 May 2020, 13:38 Ok. I'll keep checking. Ones from 99 and up won't work right? Thanks for all of the replies!
I would get a hold of the seller in the last link and ask what it came out of. The 850s used that cast number. It is a P80 head.
Active
Past
davep84
Has thanked: 1 time
Post by davep84 »
Another thought: What about buying the one from Clearwater and then putting Volvo branded valve stem seals on before I install it?
smacknab
Has thanked: 97 times
Been thanked: 43 times
Post by smacknab »
davep84 wrote: 02 May 2020, 16:05 Another thought: What about buying the one from Clearwater and then putting Volvo branded valve stem seals on before I install it?
Would you be putting in the seals yourself? If you're paying someone else to do it I think you'd be better off having a machine shop surface and fix an old one.
For reference I brought my head to a machine shop that my Volvo dealership uses and he ran my head right after another, lapped some valves and installed new seals I brought him for 350 cash. Seals cost me about 120-140 (I bought 20 individual seals from my dealer at ~$6-7 each) but I later found out Volvo sells a pack of 24 seals for cheaper.
07 V50 T5 AWD M66 ~146k miles
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Heads from '94 through '98 should work.
Caution, if the head was warped that bad you may want to consider swapping the engine. Did fluids mix?
