Did you know? 🤔
2004 Volvo XC70 codes P0740 and 2x P0700
2001 - 2007 XC-70
melmaclifeform
Year and Model: 1999 S70 Base
Has thanked: 1 time
Been thanked: 0
United States of America
melmaclifeform
Post by melmaclifeform » Fri May 01, 2020 6:42 pm
Hey all,
A few months back I purchased an XC70 to drive while I attempt to piece together my S70, and it's been great until recently where it's given me a bit of trouble.
Recently on a highway trip, it was shifting quite hard and the DTC came up with a "Transmission Service Required" message along the check engine light came on. I went and had the codes read and up came three codes- P0740, P0700, and P0700 again. Upon researching the codes, I'm pretty sure it means that I need to have my TCM repaired. What do you guys think?
1999 S70- Currently in pieces
2000 S70 GLT SE- The car that helps keep oil prices up with the amount it leaks
2004 XC70 AWD- It's the wagon
RickHaleParker
Has thanked: 3 times
Been thanked: 543 times
RickHaleParker
Re: 2004 Volvo XC70 codes P0740 and 2x P0700
Post by RickHaleParker » Sun May 03, 2020 12:23 pm
P0700 = "Transmission Control System Malfunction" rather vague and many things can trip an P0700 including a P0740.
P0740 = TCM-002F = Lock-up function. Slipping or not engaged.
Pull the connector to the TCM, clean the contacts, check for wiring defects. If that does not do the trick most likely you are dealing with a mechanical fault in the transmission. However before breaking out the wallet I would do a transmission fluid and filter change. Mechanical fault in the transmission is based on the assumption the fluid and filters are maintained.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger, Plant Ghent Belgium.
melmaclifeform
Has thanked: 1 time
Been thanked: 0
melmaclifeform
Post by melmaclifeform » Sun May 03, 2020 5:04 pm
Ok, sweet.
If it isn't that, here's to hoping it's a solenoid or something cheaper :/
E Showell
Year and Model: V70R '06 AWD Auto
Has thanked: 13 times
Been thanked: 67 times
E Showell
Post by E Showell » Mon May 04, 2020 5:54 am
Rick - don't you have to crack those trannies open to get at the filter?
'99 V70 NA FWD Auto, dark blue (actively for sale)
'06 V70 R AWD Auto, Sonic Blue Metallic
'04 XC70 Ruby Red Metallic
'95 855 auto (sold)
'86 245 manual (sold)
RickHaleParker
RickHaleParker
Post by RickHaleParker » Mon May 04, 2020 7:28 am
You Spoiler :wink:
Disassembly required. He would be best off trying just a fluid change.
RickHaleParker
RickHaleParker
Post by RickHaleParker » Mon May 04, 2020 7:45 am
If it not the connector, you need to get a Vida-Dice scan or a scan from a better reader.
The codes your reader is producing are questionable. It is possible it is a sensor that prevents lock-up. The reader you have may not be reading all the codes or mistranslating the DTCs.
