Did you know? 🤔
Transmission issues
Help, Advice, Owners' Discussion and DIY Tutorials on the Volvo S80 model. Sometimes called an "executive car", the S80 was and continues to be Volvo's top-of-the-line passenger car.
RickHaleParker
Has thanked: 3 times
Been thanked: 543 times
United States of America
RickHaleParker
Re: Transmission issues
Post by RickHaleParker » Sat May 16, 2020 2:02 am
lasseamager wrote: ↑
Sat May 16, 2020 1:46 am
That dosent mean i havent seen any else than my own - i just DONE my own 2
A thousand 4T65 rebuilds/repairs observed ... why did you invest that much time in observation?
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger, Plant Ghent Belgium.
lasseamager
Year and Model: volvo 2002 s80 t6
Has thanked: 0
Been thanked: 0
Denmark
lasseamager
Post by lasseamager » Sat May 16, 2020 3:28 am
RickHaleParker wrote: ↑
Because i have absolutely nothing else to do
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 29 times
Been thanked: 69 times
MoVolvos
Post by MoVolvos » Sat May 16, 2020 12:57 pm
MoVolvos wrote: ↑
Sat May 16, 2020 12:58 am
Fri May 15, 2020 11:28 am
i have seen it a thousand times . the band and clutches wear out.
You said you rebuilt 2 of them :?:
"i have rebuild 2 of my own ( chevrolet trans sports )"
viewtopic.php?p=542602
I guess 2 is easier to remember but is that 1000 or 1002 times that you've seen it done?
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
lasseamager
Has thanked: 0
Been thanked: 0
Denmark
lasseamager
Post by lasseamager » Sat May 16, 2020 1:05 pm
What is your problem? Do you only have a head so that its not raining right down your neck ?
MoVolvos
MoVolvos
Post by MoVolvos » Sat May 16, 2020 1:59 pm
Since we both have a head we both don't have a problem with rain down our necks unless you choose to let it pour on you. As for the head it's what's inside that counts.
In two post you've used "stupid not too" and "seen it a thousand times". People are here to learn so we are less stupid but we prefer to dialog with people a little smarter than us so we can learn rather than someone who is less stupid like yourself. That's the difference between having a head and something inside of it.
Unfortunately, I don't like umbrellas but I am not less stupid and a little smarter because I will find something to cover my head so the rain does not run down my neck. I hope I answered your question.
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
NorCalBoy
Year and Model: 2002 s80 t6
Been thanked: 0
NorCalBoy
Post by NorCalBoy » Sat May 16, 2020 7:16 pm
This is disturbing to read. I really need help figuring out what i should do with my car and logged on for honest advice and ideas on what i can do to fix it and u guys are on here being rude. go someplace else with that please..
So i have a 2002 volvo s80 turbo that is having tranny issues. It only drives in manual 3rd gear. check engine light is on so i cant smog it. code reader is showing these codes. p0700, p0751, p0756 im trying to figure out what i should do?
SuperHerman
Has thanked: 0
Been thanked: 157 times
SuperHerman
Post by SuperHerman » Sat May 16, 2020 8:17 pm
I posted my thoughts early on. The 4T65E has design issues. What you describe is consistent with a failed transmission related to the design issues. I think you need a rebuild. Clutch/hub shaft has or is failing is a possibility. Second gear clutch pack is beyond service limit is another possibility (or an additional problem). The other possibility, which is what RickHaleParker cured is failed/failing accumulator valves.
Check out this site -https://www.tripleedgeperformance.com/V ... -XC90.html
Navigate around and you will find additional non-Volvo 4T65E issues.
NorCalBoy
Been thanked: 0
NorCalBoy
Post by NorCalBoy » Sat May 16, 2020 10:05 pm
SuperHerman thanks for your feedback..
MoVolvos
MoVolvos
Post by MoVolvos » Sun May 17, 2020 4:01 pm
NorCalBoy wrote: ↑
Since you are new to the forum the people here have tried to provide the least expensive and time consuming methods to check a problem which is inherent with this transmission. You'll notice lasseamager is new and was condescending and recommending a tear down besides additional work because he was smarter and have seen it a thousand times. Most people come to learn and not pretend to have the last word.
It rarely happens that people are rude on this Forum but I and perhaps some others here don't appreciate that. Most importantly did not want you to spend a bunch of money, time and discover it was a minor issue. (EDIT $150) plus in parts and your time vs transmission rebuild.
Summary: If you've DIY for sometime, following the videos you might be able to quickly find out if you can take care of the problem without a tear down and get the car Smog. Lived in CA from 71 to 05 so know the head aches of getting a smog done in CA. I suggest you carefully read the entire post and follow the links while avoiding the disturbing parts.
Filter Change
Flush
Shift Kit
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
RickHaleParker
RickHaleParker
Post by RickHaleParker » Sun May 17, 2020 7:53 pm
Day after day seven days a week for 8 - 10 years. That what it takes to go through a 1000 transmissions. Life must be dull for you.
