So does anyone know how compatible different ECC units are ? I believe in later years, not very, but not sure about earlier years. I might be in need of one, and I'm wondering how specific I have to be if I get one from a wrecking yard.
Sveedy is a '96, and I think there is a '95 in the yard.
Thanks all !
Compatibility of ECC units Topic is solved
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
Damn I hate answering my own questions.
'93 - '97
'93 - '97
1999 V70 GLT
1999 V70 GLT
- misha
- Has thanked: 155 times
- Been thanked: 432 times
RickHaleParker would have answer to your question.
Earlier versions from '93-'95 will not work properly in your '96(probably will not even work).
The best way is to find ecc unit with same numbers like yours(part number).
Same year and same part number.
'97 would probably work fine which would have the same part number.
So...i guess that you will need ecc from '96 or '97.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Sveedy
Well doesn't that just figure. I couldn't find an answer in repeated searches, so I just went to e-bay and saw them listed ' 93 - '97.
I am hoping I don't need one, but I have no power at the low pressure switch. Would you happen to know how I can bench test the AC relay ? Seems like the only other thing between the ecc and the switch. And yes - I did check the fuse this time
1999 V70 GLT
1999 V70 GLT
- 1944 Views
- 4888 Views
Last post by CRM
- 987 Views
Last post by xnRS
- 345 Views
Last post by AlanHMultiV70s
- 1288 Views
