98 V70XC MAP/Baro sensor issue. Topic is solved
DeadEric
Year and Model: 1996 850 Turbo
Has thanked: 2 times
Been thanked: 12 times
Post by DeadEric »
I'm getting P0108 codes. I checked the sensor and its poo.
In my research I have found the it sits by the hood latch next to the washer fluid jug. It doesn't measure manifold pressure, just altitude. The sensor is $180 from worldpac, $60 from ipd and I can get a resistor for 5 cents.
My thought was, if someone could ohm check theirs I could bypass it with a resistor and rule it out for my rich AF mix.
Thanks in advance
1998v70xcbill
Year and Model: 1998v70xc
Been thanked: 3 times
Post by 1998v70xcbill »
I measured my 1998 v70xc. pin 1 front of car
pin 1 to 2 5.5k
pin 2 to 3 6.6k
pin 1 to pin 3 11.5k ohms
I'm at about 350 ft above sea level
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Get on from a junkyard, will run you about $6, and you have a lot of junkyards around you in Minneapolis. The baro sensor basically never fails but get two if you want to be sure to not have to deal with it again.
Has thanked: 2198 times
Been thanked: 1851 times
Long time since I looked at this, but if I recall there were several things on the same circuit. I can't recall but I think there were 3 things. The barometric sensor, the (can't recall the name) sensor on the front cross member and I thin the 3rd was some sensor on the A/C system near the bulkhead.
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
scot850 wrote: 04 May 2020, 11:54 Long time since I looked at this, but if I recall there were several things on the same circuit. I can't recall but I think there were 3 things. The barometric sensor, the (can't recall the name) sensor on the front cross member and I thin the 3rd was some sensor on the A/C system near the bulkhead.
Altitude sensor, A/C pressure sensor and Accelerometer share a common ground through the ECM. If something pulls the ground high or the ground opens all three will shut down.
Active
Past
Thanks Rick! I know we can rely on you to sort my feeble memory!
DeadEric
Post by DeadEric »
Thanks for the help, this info is perfect.
RickHaleParker
scot850 wrote: 04 May 2020, 16:00 Thanks Rick! I know we can rely on you to sort my feeble memory!
If your relying on me, your in bad shape. :wink: :lol:
Active
Past
