Hi All,
I've got a 1998 V70R FWD and finally decided I would stick a tow bar on it, I found one from a "MK1 V70" on ebay for £50 delivered... perfect. It arrived, I looked under the car but my car doesn't seem to have any bolts at the spacing on the frame... how bizzare...
Obviously I don't have any fitting instructions as it's from a breakers so I'm going by eye here, either I'm missing something about how it fits or maybe the R has a different chassis design? I found a vague reference elsewhere online that suggested the the R might need a towbar that suits the AWD? I know the front control arms on the R are the heavy duty versions, the same as the diesels and mount differently so perhaps there's some other differences too?
I've attached a photo of the towbar behind the car so you can see the hole spacing and approximate widths of the bolts but I forgot to take any photos under the car.
Towbar on V70R
NewKidOnTheBlock
- Year and Model: 1998 C70 T5 Coupe
- Has thanked: 1 time
Richard99
- Year and Model: 2000 V70XC
- Has thanked: 26 times
- Been thanked: 23 times
Hi NewKidOnTheBlock,
That tow bar may work, but you might want to consider another style, with all of the stuff in the way for the AWD vehicles. I can show you how mine is on my 2000 V70XC, which should have a similar rear end to yours, and offer up other suggestions. I can post pics tomorrow since it's so late here in the U.S.
Eric
1998 Volvo V70 - rear-ended and totaled
2000 Volvo V70XC
2007 Volvo V50 T5 AWD M66
2000 Volvo V70XC
- kranz
- Year and Model: '98 V70 NA stick
- Been thanked: 8 times
In the US, a different style is common that requires no modifications to the frame and uses only three bolts
Instructions are here:
https://www.draw-tite.com/support/insta ... N36262.pdf
Les is more.
NewKidOnTheBlock
Thanks all for your comments, I've found that the seller sent me the towbar without the brackets! Refund is on it's way and now to find another FULL kit!
Cheers
Cheers
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
Why don’t they put a better coat of paint on those things?
- 616 Views
Last post by dtbr44
- 603 Views
Last post by dh058977
- 1552 Views
Last post by bmdubya1198
- 3414 Views
Last post by KurtL
- 212 Views
