Amazon Cyber Monday 2020
removing rear tailshaft cv joint xc70
2001 - 2007 XC-70
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 22 times
Post by darrylrobert »
Has anyone replaced/checked/serviced their prop shaft cv joints. i didnt notice but the boot on my forward cv joint had torn. I checked my spare parts vehicle and the front cv was also torn but the rear wasnt.
Apparently the rear cv joint is not to be removed, you need to buy a complete tailshaft. i can confirm it does come off like the front but not easily, and it may be just as hard putting it back.
The rear boot is black like rubber, the front is grey like silicon.
Replacing the boot you need to remove the cv joint, not the driveshaft. dont think its possible without removing the Angle gear.
After packing new grease it moves alot better than it did, i put alot of grease, hopefully the boot doesnt explode.
removal rear cv joint
2001 XC70 factory M58
2002 XC70 auto (parts car)
- Pete -
Has thanked: 64 times
Been thanked: 117 times
Re: removing rear tailshaft cv joint xc70
Post by - Pete - »
As far as I know, and this is true on my 04-06’s, the front and rear CVJ is the same part. Check with coloradodriveshaft.com & they can verify if your earlier XC is the same. I can say their CVJ’s & boots are every bit as good as the ghastly expensive Volvo CVJ’s.
They use CVJ’s which are made in Turkey & Poland & the boots are very thick and durable.
Alternatively, and I have done this, you can source a very cheap CVJ kit off eBay & just use it for the boot, & have the actual CVJ for making welded art etc. They make for pretty cool eyes for terminator/robot looking creations.
As you know, and for reference for future readers, you pop this cap off, then remove the circlip beneath it.
2001 V70XC 151k
2004 V70 AWD 145k
2004 V70R M66 146k
2004 XC70 293k
2006 XC70 155k Sold
SuperHerman
Been thanked: 174 times
Post by SuperHerman »
As Pete explains you can remove either CV end for rebuild/repair. As his picture shows the entire driveshaft can be removed without removing the angle gear.
For removal: Detach the front CV (support it), detach the center carrier (support it), detach the rear CV (like the front).
I have replaced the front CV and boot with rebuild kit and cleaned and repacked the rear without issue.
