Did you know? 🤔
Groan/catching sound while turning - mechanic says rubbing strut springs
Year and Model: 2001 V70
Has thanked: 23 times
Been thanked: 59 times
United States of America
Re: Groan/catching sound while turning - mechanic says rubbing strut springs
Post by volvolugnut » Sat May 16, 2020 12:04 pm
In the third photo I can see the fender liner mounting hole is torn from the plastic nut. This lets the fender liner flap and will rub the wheel when turned to the right.
2001 V70 T5, 1986 244DL, 1983 245DL, 1975 245DL, 1959 PV544, multiple parts cars.
smacknab
Year and Model: 99 s70 NA Manual
Has thanked: 58 times
Been thanked: 12 times
smacknab
Post by smacknab » Sat May 16, 2020 12:19 pm
I popped it out to access the motor mount, it seems to hold pretty tight when I put it back in.
99 s70 NA m56 - >213k miles
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 28 times
Been thanked: 69 times
MoVolvos
Post by MoVolvos » Sat May 16, 2020 12:53 pm
Difficult to see but it looks like the spring end is not seated in the spring perch. If so the spring may not be centered (floating) with the strut and rubbing against the body?
The spring end perch has a spot where the spring end rest. I added a tubing on the spring end just in case the spring end rubs against the perch. The tubing is cut at an angle so it does not hold water and debris.
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
smacknab
smacknab
Post by smacknab » Sat May 16, 2020 1:03 pm
I was wondering about that, but it looks like I've got it in the chanel? How do these photos look?
The first photo is with the car on the ground wheels straight forward. second photo of the strut mount is with the car jacked and the wheel off
MoVolvos
MoVolvos
Post by MoVolvos » Sat May 16, 2020 1:18 pm
smacknab wrote:
Thu May 07, 2020 3:15 pm
For some background I just replaced my entire front suspension over the last few months with the FCP Sach kit (Sachs struts, Sachs spring seats, Sachs strut mounts) plus new lesjofors springs.
If you have the old strut assembly compare it with your new set up since everything is new. Double check all your part numbers for fitment / correct application and then look at the bottom of the spring sitting properly in the spring perch.
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
MoVolvos
MoVolvos
Post by MoVolvos » Sat May 16, 2020 1:25 pm
I see the spring spiraling inward on the top and bottom so it seems OK. Do you get an alignment print out of before and after specs? I'll check Volvo's diagram to see if it's possible that something could be bent so the SAI angle is off one side vs the other.
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
MoVolvos
MoVolvos
Post by MoVolvos » Sat May 16, 2020 1:39 pm
I don't see anything that's obvious. The knuckle can't be bent so if anything is off would the strut or LCA being bent. It would have to be such so the strut is pushed towards inner portions of the fender well.
99 S70.png (210.7 KiB) Viewed 35 times
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
smacknab
smacknab
Post by smacknab » Sat May 16, 2020 1:51 pm
Hey Mo,
Thanks for looking that up. He's a photo of the alignment I got in March.
And this is the kit I used,
https://www.fcpeuro.com/products/volvo- ... em-vfsk2-s
looking at all the parts according to FCP they are the correct units. Only difference they note is the spring seat is the updated XC90 style.
Springs I used
https://www.fcpeuro.com/products/volvo- ... 16#fitment
Tie rod kit
https://www.fcpeuro.com/products/volvo- ... er-kit-kit
End links
https://www.fcpeuro.com/products/volvo- ... 0fsblkt2p2
Control arm
https://www.fcpeuro.com/products/volvo- ... 70-v70-850
I still have the old strut assemblies so I can dig those out
MoVolvos
MoVolvos
Post by MoVolvos » Sat May 16, 2020 2:16 pm
The alignment specs look good. More Caster on the left and more negative Camber right front and rear so the car will still drive straight on the crown of the road. Positive toe front and rear with no thrust angle or steer ahead also promotes driving straight and perform well if the steering wheel is centered. They don't show SAI which helps to diagnosis bent suspension parts but I think your alignment tech would probably say something if he saw that it was off. Specs will also help reduce tire wear. I'll take a look at the parts.
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
smacknab
smacknab
Post by smacknab » Sat May 16, 2020 2:43 pm
Thanks for that analysis. I'll post back here when I check out the old suspension
After I inspected the motor mount I tried to make sure it was set in straight and torqued well. It seems like the sound is a little more quiet, but it could be a red herring
