Welcome to the world's #1 Volvo forum!
Volvo Fixes & Advice since 2001.
Programming parts?
Yaworski
Year and Model: 2002 S60
Been thanked: 3 times
Programming parts?
Post by Yaworski »
A couple years back I had to replace the ETM. It had to be "programmed" to work with the car.
Apparently, ABS is the same way.
Why? What strange and mysterious things need to be "programmed"?
Is that a valid and sound technical reason that these things can't be plug-n-play?
Has thanked: 504 times
Been thanked: 1506 times
Check with Yagger about ABS programming
Having software stops us from having to pay for a supply chain of 81 versions of ABS controller
Yaworski
Post by Yaworski »
abscate wrote: Fri May 08, 2020 11:25 am Having software stops us from having to pay for a supply chain of 81 versions of ABS controller
If that was true, those things wouldn't be so expensive.
BTW, I sent Yeager a PM about programming and never heard back.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 336 times
Post by oragex »
For the ABS module, people tried to swap without programming, having correct updates on forums is not always easy, but I seem to remember that if you get it from same year with same part number, chances are it will work without programming. The throttle body was particular on 01-02 (unfortunately), but there are several other modules that don't need programming when swapped - however the main dealer will tell sometimes otherwise
vtl
Year and Model: 2005 XC70
Has thanked: 9 times
Been thanked: 112 times
Post by vtl »
I think Volvo has a logic view of internal network for design/simulation where modules are addressed by labels, not by numeric IDs. When the design is finalized, the design software enumerates the modules and the variables/toggles in these modules and assign them numeric IDs. Adding another toggle to a new software version for one module may shift enumeration in this module or even in the network, so the IDs mismatch now between old and new software versions. If that happens, the software update to the car for that module needs to update a bunch of modules that communicate between each other.
05 XC70, 16 XC60, 19 Tundra
P1+P2 CEM PIN-code retrieval DIY thread: viewtopic.php?f=10&t=85611
Yaworski wrote: Fri May 08, 2020 11:28 am
He was probably out on a test flight, out of sound
Try website
https://www.datatransferring.com/online
Password of the day : total
yagger
Year and Model: S60 2005 2,5T
Has thanked: 6 times
Been thanked: 31 times
Post by yagger »
Yaworski wrote: Fri May 08, 2020 11:28 am BTW, I sent Yeager a PM about programming and never heard back.
Sorry, but I never received some PM from you.
yagger
Post by yagger »
Yaworski wrote: Fri May 08, 2020 10:59 am Why? What strange and mysterious things need to be "programmed"?
It depends on case. Sometimes not need to program module.
Yaworski
Post by Yaworski »
yagger wrote: Fri May 08, 2020 2:37 pmSorry, but I never received some PM from you.
I misspelled your name. I just sent a PM.
