Shifting issues
AnotherVolvo2003
- Year and Model: 2003
Ok, I have a 2003 XC90 T6- I know great transmission! Anyway, it has 82,000 miles, the transmission was of course out, had it dropped and the clutch packs replaced and anything else in the master rebuild kit. Put it all together and is was fine for a few weeks. Now I have a “Service Transmission” message coming up and it won’t get out of third gear. After I turn off the engine then later restart it, the message is gone and it’s fine for a little while then does it again. Does anyone have any ideas? Thanks
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Did you add the Transgo Shift Kit? If you replaced the clutch packs because it was needed and did not install the Shift Kit it might be back to normal bad. TrippleEdgePerformance recommends the Shift Kit during rebuilds to help with shifting points and other shift related issues inherent in the problematic design.AnotherVolvo2003 wrote: 08 May 2020, 20:39 Ok, I have a 2003 XC90 T6 - the transmission was of course out, had it dropped and the clutch packs replaced and anything else in the master rebuild kit.
viewtopic.php?f=11&t=88630&p=504849#p504849
- shiloh51933
- Has thanked: 28 times
- Been thanked: 17 times
Is it going into "limp home mode"?AnotherVolvo2003 wrote: 08 May 2020, 20:39 Ok, I have a 2003 XC90 T6- I know great transmission! Anyway, it has 82,000 miles, the transmission was of course out, had it dropped and the clutch packs replaced and anything else in the master rebuild kit. Put it all together and is was fine for a few weeks. Now I have a “Service Transmission” message coming up and it won’t get out of third gear. After I turn off the engine then later restart it, the message is gone and it’s fine for a little while then does it again. Does anyone have any ideas? Thanks
Do drive it anymore if it is going into limp mode. Did you have a software update installed after you installed master rebuild kit?
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
- shiloh51933
- 455 Views
Last post by dejongmc
- 1352 Views
Last post by bmdubya1198
- 795 Views
- 20 Replies
- 1513 Views
- 1023 Views
Last post by precopster
