2000 s40 misfire after changing spark plugs.
Hello all, I own a 2000 s40 that ran fine before doing routine spark plug change, replaced them and car misfired bad. After double checking that I had cylinder 1 connected to 4 and 2 to 3, I replaced the plug wires and coils to no avail. Now the car wont even turn over. The fuel pump is working. I just don't know what to do next. Please help!
- alschnertz
- Year and Model: 1995 854T
- Has thanked: 2 times
- Been thanked: 12 times
What kind of plugs did you use?
What did you gap them to?
If it ran before changing the plugs then it's likely something simple.
Check your coil connections - including the wires within the connectors.
"Now the car won't even turn over"
Does that mean no crank or no start?
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
Bodhi5
- Year and Model: 2001 s40
Hi, I just didn't NGK platinum plugs, got some rough firing. My right coil is connected to far left plug, n second coil on center right is connected to left middle plug.
I charged battery using new Canadian tire genius multi battery charger full, sanded both blue negative contact to engine, n frame under battery, n added a home 120 copper wire also from blue frame to any screw by the plugs for better grounding. Firing plugs. Now everything is smooth like new. Exhaust doesn't smell like gas.
- 2301 Views
Last post by Wright Sounds
- 11 Replies
- 576 Views
Last post by TJsPOV
- 16 Replies
- 4452 Views
Last post by shiloh51933
- 3312 Views
Last post by ndphotonl
- 1949 Views
Last post by Bodhi5
