Did you know? 🤔
2000 s40 misfire after changing spark plugs.
1996 - 2004 S40
1996 - 2004 V40
Jaerich76
Year and Model: 2000 s40
Has thanked: 0
Been thanked: 0
United States of America
Jaerich76
Post by Jaerich76 » Sat May 09, 2020 11:16 pm
Hello all, I own a 2000 s40 that ran fine before doing routine spark plug change, replaced them and car misfired bad. After double checking that I had cylinder 1 connected to 4 and 2 to 3, I replaced the plug wires and coils to no avail. Now the car wont even turn over. The fuel pump is working. I just don't know what to do next. Please help!
alschnertz
Year and Model: 1995 854T
Has thanked: 2 times
Been thanked: 9 times
alschnertz
Re: 2000 s40 misfire after changing spark plugs.
Post by alschnertz » Tue May 12, 2020 1:46 pm
What kind of plugs did you use?
What did you gap them to?
If it ran before changing the plugs then it's likely something simple.
Check your coil connections - including the wires within the connectors.
"Now the car won't even turn over"
Does that mean no crank or no start?
'84 Prelude
'06 MPV
'13 Ford Focus SE
Bodhi5
Year and Model: 2001 s40
Has thanked: 0
Canada
Bodhi5
Post by Bodhi5 » Mon Jun 15, 2020 1:42 am
Hi, I just didn't NGK platinum plugs, got some rough firing. My right coil is connected to far left plug, n second coil on center right is connected to left middle plug.
I charged battery using new Canadian tire genius multi battery charger full, sanded both blue negative contact to engine, n frame under battery, n added a home 120 copper wire also from blue frame to any screw by the plugs for better grounding. Firing plugs. Now everything is smooth like new. Exhaust doesn't smell like gas.
Bodhi5
Has thanked: 0
Canada
Bodhi5
Post by Bodhi5 » Mon Jun 15, 2020 1:44 am
Battery and/ or alternator dead!
