Failure to clear code 122 - cruise control
theiceman69
Year and Model: 850 wagon - 1995
Has thanked: 2 times
Post by theiceman69 »
It was working fine before I replaced Part A of the OBD, failed to engage some little while later and now will not reset :!: :roll:
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
I believe that's a pre mph requirement code. What's the real issue? Cruise not working?
theiceman69
rspi wrote: 11 May 2020, 07:48 I believe that's a pre mph requirement code. What's the real issue? Cruise not working?
Yes, it fails to engage, I normally select it around 75/78Kph(near to 50Mph) but it does not come in.
It is in the OFF position most of the time - not left ON - as this may pick up a "low speed signal" as it did once before, hence my leaving it OFF.
Tried disconnecting the - side of battery for 10/12 mins but no change. :?
