2005 XC90 Engine Swap
Batty251
Year and Model: 2005 Xc90
Post by Batty251 »
Morning all,
I am about to swap an engine on a Volvo xc90 2005 model from a T6 4 speed to a 2.5T with the ECU and Ignition immobilizer to match the ECU as well as swapping the guts from the other key to the key already in use for the door handles and Ignition barrel so no issues of starting.
Can anyone else recommend any other kind of precaution or checks i will need to who has done this kind of swap before? Also note the reason i am swapping is because the engine in the car already is blown.
Thank you.
wanderdüne
Year and Model: 2004, 2006 XC90 2.5T
Has thanked: 6 times
Been thanked: 45 times
Post by wanderdüne »
The 2.5T won't bolt up to the GM transmission.
Batty251
Post by Batty251 »
I already have the 5 speed transmission that comes with the 2.5T.
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
Batty251 wrote: 11 May 2020, 08:50 Can anyone else recommend any other kind of precaution or checks i will need to who has done this kind of swap before? Also note the reason i am swapping is because the engine in the car already is blown.
If the new engine and transmission is coming from another P2. Swap the entire subframe assembly and engine bay wiring harness. Disconnect harness under the dash, pull it out of the cowl then work it loose. But do not disconnect harness from the engine and transmission.
Disassemble front of car, headlights radiator, bumper. That will open up the front. Then you lower the subframe assembly about a decimeter and pull it straight out the front.
Active
Past
Batty251
Post by Batty251 »
So the engine won't come out from above ? i planned to strip the engine bay and put in every piece one by one after i manage to fit in the engine and transmission. Also the reason i am stripping it isn't just clearance but to make sure every part of the engine bay is in functioning order and to clean up all the parts. I heard maybe the differential might be different maybe, dose anyone know if this is true or not?.
wanderdüne
It seems like you would have to swap everything over, including the sway bar, axles etc. Not sure the hubs have the same splines from the T6 to the 2.5T. Also, the prop shaft might be a different length. I don't know if the angle gear is different, but would assume so. Look here: https://www.tascaparts.com/auto-parts/volvo
RickHaleParker
Batty251 wrote: 12 May 2020, 01:19 So the engine won't come out from above ?
If you unbolt the Engine and Transmission from the Subframe you can pull up. It would be less work and easier to do as described above. That is if you are swap P2 to P2.
Batty251 wrote: 12 May 2020, 01:19 I heard maybe the differential might be different maybe, dose anyone know if this is true or not?.
What is the donor? Cannot do a comparison if we don't know what the donor is. That would be like planning a road trip when you do not know where you are.
Active
Past
Batty251
Post by Batty251 »
Sorry for leaving out some additional details.
Donor car is a 2004 Le 2.5T Volvo XC90 AWD.
Complete car that i am swapping things into including the new trans and engine is a 2005 LE 2.9T Volvo XC90 AWD. Both are auto.
I have already summed up that the drive shaft is 4 inches short for the 2.5T which i am trying to see if getting a whole new drive shaft or make up that extra 4 inches some how as my best guess is because the 2.9T is just that little big bigger it might push the transmission further into the body making that drive shaft that 4 inches shorter, However if i mount the 2.5T in a way that would match that of the 2.9T the drive shaft might match up as their both the same holes and bolt points according to a service manual i own.
RickHaleParker
Batty251 wrote: 13 May 2020, 00:59 Sorry for leaving out some additional details.
2004 XC90 2.5T / 5 speed: Final - Drive Ratio 2.86 : 1
2005 XC 90 T6 / 4 speed: Final - Drive Ratio 3.69 : 1
You will need to find a rear differential with a ratio of 2.86 : 1
Wait until you get the engine/transmission swap done then see if one of the two driveshafts will fit. If nether fit, a machine shop can cut the ends off and make a driveshaft any length you need and balance it.
Active
Past
Batty251
Post by Batty251 »
So the transfer case will be fine ? just gotta swap the differentials ?
