Hi,
My daughters 2008 xc90 A/C system works but seems to have low air volume and takes a while to cool the car down. The air is cold in the vent.
I have noticed if I remove the cabin filter it does increase the volume.
Is this a known issue?
Any suggestions?
XC90 A/C Blower Volume
wanderdüne
- Year and Model: 2004, 2006 XC90 2.5T
- Has thanked: 6 times
- Been thanked: 45 times
Does it make a difference if it is on recirculate?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
The thick charcoal cabin filter does reduce the airflow. May also look at the blower from above (need to lift a little the windshield cowl) see if it's clogged with leaves. If the car has many miles, the blower motor may have worn brushes or may be seizing. Also look at the ac compressor lines around the engine, do they look covered with ice ? www.youtube.com/watch?v=s1vIWTG9-Zw
lancelyons
- Year and Model: 2008
Thanks for the info. There is no compressor or A/C lines covered in ice. It seems like when she brakes or accelerates the volume changes.
Do the XC90s have a lower blower volume? Are there higher volume blower fans that can be installed?
wanderdüne
You could check the voltage when the vehicle is running at the + stud on the driver side in the engine bay to make sure the alternator is outputting correct voltage ~14V or more.
The blower, although doable, isn't something you want to replace unless it's not operating correctly. Volvo's have an "adequate" air volume.
lancelyons
thanks. that helps. will make sure there is no leaves around the inlets as well
- 1764 Views
Last post by dahammer
- 673 Views
Last post by wole1
- 2131 Views
Last post by mrbrian200
- 1020 Views
Last post by wizechatmgr
- 732 Views
Last post by RickHaleParker
