Did you know? 🤔
CCM/ECC not working. No control of damper motors. AC ON-button blinking Topic is solved
kallekula
Year and Model: S70 2000
Has thanked: 18 times
Been thanked: 15 times
United States of America
kallekula
Post by kallekula » Wed May 13, 2020 8:12 am
Volvo S70 2000
Vents only blew hot air so I spent some time yesterday trying to fix it without success. I took out both blender motors and directional motor and they run fine on the bench in both directions when I put power on them. However, whatever knob I turn on the ecc control panel does nothing. No motor turns. The AC ON button blinks green constantly. I tried resetting/calibrating the motors using vida but it immediately goes to "Not Completed". Error codes are only "calibration can not be performed" (something like that). I went to the junkyard and bought a new control panel and also a cabin temp sensor but the problem remains. What the heck is going on? Does anyone have experience with this kind of problem? Jimmy57??
BMW 540i 2002
S70 Base 2000
S40 T5 2004.5 (For Sale)
Has thanked: 12 times
Been thanked: 210 times
Canada
Re: CCM/ECC not working. No control of damper motors. AC ON-button blinking
Post by scot850 » Wed May 13, 2020 1:07 pm
Now that is weird. The fact that it only blows hot air would suggest the blend motor is not being activated. But is you manually tested it's limits then that should be it, it should work. Then you change the position of the direction switches, can you see if the blend motor works in both directions?
As to hot air only, that would also possibly mean the cold air flap motor is not working. Again easiest to see servo motor to see operating. Check to see the flap has not stuck closed, and also the filter is clean.
A faulty cabin sensor would potentially cause the ECC not to be able to check the cabin temp. Again you can check that wither or both the motors work but leaving the EC connected and removing the sensor from behind the dash to check that the little fan is working. These can jam over time with a build up of environmental crap/hair/dust. I clean them carefully with IPA, cotton buds and small artists brushes. I then test the fan works with a 9V battery and a couple of wires.
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
kallekula
kallekula
Post by kallekula » Wed May 13, 2020 4:47 pm
yes the motors work fine on the bench. I also took them off but left them hanging connected in the car. The blender motor, recirc motor and directional motor is not moving when i turn the knobs on the ecc panel. On the bench they move fine in both directions. Driving me nuts! HEEEEEEELP
EDIT: and i checked the temp senbsor. According to vida it reads correct temp and the fan is working. also tried with another one from the bone yard.
ONE lamp on the ECC panel is blinking green. It is the AC on button. The only thing that works is the fan speed slider control. I can also turn the compressor on/off. Thats it, but i cant control any of the damper motors.
BMW 540i 2002
S70 Base 2000
kallekula
kallekula
Post by kallekula » Thu May 14, 2020 3:14 am
* After car is started the AC on button starts blinking green. Not just for a few secs but continuously
* The only control I have over the system is that I can adjust fan speed and turn compressor on and off
* Temperature on driver and passenger side can not be adjusted
* Direction of air can not be adjusted
* Recirculation can not be changed
* Two different ecc panels tested
* Two different cabin temp sensors tested
BMW 540i 2002
S70 Base 2000
Canada
Post by scot850 » Thu May 14, 2020 2:04 pm
Been a while, but is there perhaps a separate fuse somewhere for the servo motor operation which allows the ECC to flash but not actually operate? This is where we need someone more familiar with the electrical side.
Have you confirmed the ECC replacement is the same model as your original. These units seem to have an endless number of part numbers, but I think there may have been a change physically in around 98-99, but don't quote me on that!
Last thing. Have you done a hard system re-set? The detaching the battery cables and touching them together?
2006 XC70
kallekula
kallekula
Post by kallekula » Thu May 14, 2020 3:49 pm
yes I done all that. hard reset as you call it, fuses (the ones i could find), no fault codes. panel came out of same model car same year. exact same behaviour, just the ac on lamp blinking. I even went to the junk yard again this morning and bought a new directional motor but no cigar. I actually saw the directional motor move a little bit this morning when i played around with it. but after that nada. frikkin volvo crap. Like you say there might be more fuses or relays buried somewhere who knows. Most annoying fault I ever had to deal with.
BMW 540i 2002
S70 Base 2000
Has thanked: 316 times
Been thanked: 981 times
Trinidad & Tobago
Post by abscate » Fri May 15, 2020 2:03 am
Normally I’m in Laguna Beach every month or so, but I’m sequestered away from Corona Del Mar here in NY
You need software to read the codes and tell you what’s faulting. It’s likely the fault is shutting down signals from the control Unit, sort of like certain engine codes turn off boost
Link To Volvo Glossary
kallekula
kallekula
Post by kallekula » Fri May 15, 2020 5:07 am
I have VIDA to read codes. Isn't that enough?
BMW 540i 2002
S70 Base 2000
Trinidad & Tobago
Post by abscate » Fri May 15, 2020 6:23 am
Yes - go to the ECC module (?) and you should be able to see the faults - I don't know VIDA that well but my AUTEL actually reads these same VOLVO error codes for my ECC (I have a recirc door that occasionally sticks and throws a code)
kallekula
kallekula
Post by kallekula » Fri May 15, 2020 6:24 am
Been there done that
That's the annoying part, how to fix if there are no codes. All this crap started when i ran the damper motor calibration thingy in Vida...
There is of course a small chance i got a used one that was also broken. Whats the failure rate on these control panels?
BMW 540i 2002
S70 Base 2000
