Did you know? 🤔
Starting replacement of control arms and ball joints on 2005 XC90 2.5t this weekend
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
volvooh
Year and Model: '98 S70, '05&'08 V70
Has thanked: 0
Been thanked: 3 times
United States of America
volvooh
Re: Starting replacement of control arms and ball joints on 2005 XC90 2.5t this weekend
Post by volvooh » Mon May 18, 2020 8:37 am
Wandrdune- Did you completely remove the axle from the hub, or were you able to articulate the hub enough with the axle in the join the control arm to the ball joint?
wanderdüne
Year and Model: 2004, 2006 XC90 2.5T
Has thanked: 4 times
Been thanked: 38 times
wanderdüne
Post by wanderdüne » Mon May 18, 2020 8:59 am
volvooh wrote: ↑
I did not remove the axle, just removed the screw and then re-threaded it a few turns. I lubed the splines to assure inboard and outboard movement. I just held down the arm with my knee using a "mechanic pry bar" against the sub frame. The action is more to lift the hub up, over and forward to get the ball joint into the arm while pressing the arm down. Left to it's own devices, the arm will sit at rest just to the side of the ball joint
volvooh
Has thanked: 0
volvooh
Post by volvooh » Tue May 19, 2020 2:09 pm
Just out of curiosity, should the ball joint nut be tightened to a specifc torque spec? I've read anywhere from 37 to over a hundred ft pounds. I did not use a torque wrench. I just used by 3/4 ratchet and tightened as hard as I was able by hand.
ggleavitt
Year and Model: XC90 05-2.5T, 08-V8S
Has thanked: 0
Been thanked: 60 times
ggleavitt
Post by ggleavitt » Tue May 19, 2020 2:44 pm
2005 2.5T AWD-200k
2008 V8 AWD Sport-130k
oragex
Year and Model: S60 2003
Has thanked: 95 times
Been thanked: 265 times
Canada
oragex
Post by oragex » Thu May 21, 2020 10:50 am
If you have a regular ratchet, slide an electric pipe (hardware store) over the handle. But it's good to know how much to torque because a 1ft or 2ft pipe will put a lot of torque will little effort. I use a 2ft breaker bar for them wheel lugs, and even without forcing too much, it puts way more than the spec 100ft-lb or so. The best I thing imho is a beam torque wrenches with the right range, cheap and no worries about getting off caliibration.
