No start
Locked
jason1973
Year and Model: 2006
Post by jason1973 »
Ok so I have a 2006 xc90 , v8 awd and thought I had a bad starter or solenoid problem so I have a new battery and solenoid and starter are good and when I bypass the relay, attempts to crank but doesn't actually start ,'with key on ,..also it does only click once during attempts to crank with key ,idk where to go from here ,maybe the throttle control sensor? It has given me problems already
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
If starter is ok,then check the grounds and b+ cable from battery to starter.
Battery terminals must be clean and tight.
If that is ok..then starter or solenoid is bad.
That click you have is pointing to one of them.
You're on the wrong forum section.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Jason73chipley
Year and Model: 2006xc90
Has thanked: 2 times
Post by Jason73chipley »
Oops sorry
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2865 times
Been thanked: 1332 times
Post by matthew1 »
No problem. Locking this so there's no confusion. The topic is now here.
Also -> Amazon link
Locked
