P0017 code.
KevinCro
- Year and Model: 2004 xc90
- Has thanked: 7 times
Hey guys. Back again. 2004 XC90 with 2.9 engine. I’ve been trying to figure out a p0017 code. My crank and cam sensors are new. The vvt solenoid is new with a new gasket. The guy I bought the car from said that he had the head shaved after a blown head gasket. The car has no torque at all. I put a new timing belt on and set the timing with the cams locked. Is it possible that the exhaust cam was installed wrong and that’s what’s causing this? Can’t that be corrected without removing the head? Thanks guys.
2004 Volvo XC90 T6 169k miles
hrblockgirl
Do you know if the timing is the same on a 2004 xc90 2.9l as on a 2.5l are they different
- 11 Replies
- 2752 Views
Last post by bmdubya1198
- 20 Replies
- 10259 Views
- 1745 Views
Last post by daimyo
- 5194 Views
Last post by Goldchemist
- 14828 Views
Last post by precopster
