Driver front turn signal is blinking fast when signaling
AndyTexas
Year and Model: 1997V70
Post by AndyTexas »
Hi everyone I need some help, I have a 1998 Volvo V70. When I turn left and push the turn signal down to turn left the light blinks rapidly fast and very quickly. I do not know what is causing this. Please does anyone know or have any advice on what I need to do. I read somewhere that it was the socket for the turn signal. I do not know and would really be very helpful for me.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
More than likely, your rear left turn signal is out.
If that’s the case, replace the lamp.
smacknab
Has thanked: 97 times
Been thanked: 43 times
Post by smacknab »
Ditto to that, I haven't had that on my Volvo but it happened on a 2010 ford I owned and it was the turn signal bulb
07 V50 T5 AWD M66 ~146k miles
Has thanked: 2197 times
Been thanked: 1850 times
Like the guys said, and switch it on, and walk around the car to see which light is not working. Replace the bulb even if it looks ok. Clean the contacts on the bulb holder if you can before installing a new bulb. Check it works before fitting the cover back on.
AndyTexas
Post by AndyTexas »
Thank you for the responses. I have not looked at the rear turn signal, but will tomorrow morning. I will get back with ya'll.
Again thank you for taking the time to respond.
JLv70t5
Year and Model: 1998 v70t5
Has thanked: 11 times
Post by JLv70t5 »
If your rear blinker is working you may need to replace the front socket. This happened on my passenger side both lights worked but blinked fast.replaced the socket on the front and it fixed it
Quicken
Year and Model: 850GLE-96
Has thanked: 3 times
Post by Quicken »
I have a similar issue except it's a bit more elaborate. When I turn on right signal, it could 1. blink very fast and the fog light on dash may intermittenly come on, or 2. blink very fast and my high beam front light may intermittenly come on. I could negate this rapid blinking and (other lights coming on) by switching to night light and turning on the switch for the rear fog light to come on. Then everything becomes okay for now. I tried switching out different combination of light bulbs and it's not fixed by any means. For example when I switched out the rear right turn signal light bulb, the new bulb had the same problem and worse, the other lights were coming on more often? I have a 1996 - 850 - base, 4dr sedan, auto trans, first owner.....
Has thanked: 1609 times
Been thanked: 4064 times
You have one or more bad grounds Aldo make sure you don’t fix up the ‘fog lamp’ bulb with the ‘ lamp failure ‘ warning bulb
