I have a XC60 T6 3.0 I am trying to figure out what this coolant hose is called to get a new one. On passenger side, It is a fitted hose with a clamped end and a screwed in fitting. From block and goes to the the other side of the oil filter. Its probably 5-6" long kinda "S" shaped i cant find one online to order by name. My daughter wss driving home and it blew out. Sorry i dont know how to put a picture up but is similar in design to Coolant Hose - 30713530
Thanks for any help
Coolant line from block Topic is solved
GoLuckydog
- Year and Model: xc60 2010
- Has thanked: 1 time
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
Take a look at this link
https://www.freel2.com/forum/topic32245.html
I believe the hose you are looking for is (part numbers are from Land Rover)
LR001442 - Coolant Hose for heat exchanger
LR000491 - Bolt for Heat exchanger hose
LR001505 - O-Ring for heat exchanger hose
You will need the hose and the O ring
If you prefer to buy the part in a Volvo box
Then use this part number 30713530
I don’t know the part number for the O ring from Volvo
Which is why I just buy the Land Rover part
I did change this hose and O ring on my S80 and LR2 (before it started leaking)
Good luck
Paul
Good luck
Paul
GoLuckydog
Thank you Paul. THAT is the exact hose I had mentioned above! Weird that the site I went to previously to purchase said it was for a different engine code. I must not have read the VIN right.
Thanks Again
Mike
Thanks Again
Mike
- pgill
Mike,
It's not that hard to replace.
Just remember to remove the old O-ring and plastic pieces from the engine block.
This is a common failure point on the 3.2 and 3.0T
I plan to replace mine every 10 years or every 100,000 miles.
You should also be thinking about replacing the Thermostat because it has a similar lifetime to the coolant hose that failed on your XC60.
Good Luck
Paul
2010 S80 3.2
2008 LR2 3.2
Good Luck
Paul
2010 S80 3.2
2008 LR2 3.2
GoLuckydog
Ive replaced the thermostat last year. The metal factory band slid off the hose. I will make sure everything comes out. I only plan on having the car maybe 2 more years. After my daughter finishes her masters program. The csr has a lot of highway miles, my wife,her old car, is in sales, just gotta get it thru a little longer. Thanks for the tips ive ordered the hose and O-ring today.
- 18 Replies
- 3792 Views
Last post by BlackBart
- 783 Views
- 21 Replies
- 7868 Views
Last post by foggydogg
- 2347 Views
Last post by Centex Swede
- 1311 Views
