Amazon Black Friday deals
Put in a used heater core...
TheOtherside
Year and Model: 1998 V70R
Has thanked: 55 times
Been thanked: 5 times
Post by TheOtherside »
No more foggy windshield or steam pouring out the vents
But it doesn't get very warm...
Any idea what the problem might be?
98 V70R
13 Flex w/EcoBoost
crlande
Year and Model: 240DL;850;S70
Been thanked: 26 times
Re: Put in a used heater core...
Post by crlande »
clogged core, bad thermostat, blend door issue?
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 61 times
Been thanked: 39 times
Post by Cookeh »
The above, plus potential trapped air in core.
Has thanked: 413 times
Been thanked: 1270 times
New foam needed around heater core, or else the air doesn't go through it.
If your cooling system is working ok, it is doubtful the core is clogged since they are full flow.
Link To Volvo Glossary
TheOtherside
It gets warm, takes a bit, but definitely gets warm.
Gets colder at idle after 5 minutes.
98 V70R
13 Flex w/EcoBoost
ecbsykes
Year and Model: 2000 V70XC
Has thanked: 36 times
Been thanked: 43 times
Post by ecbsykes »
Did it get super hot before (foggy window and all?)
If so, my bet is on trapped air or like abscate said the foam insulation around it. Let the system warm up to full temp with the coolant reservoir cap off, rev a little to try and get things moving around a bit to purge system of air. Carefully see if you can reach and (emphasis on carefully) feel any heat of the heater hoses going into the cabin.
2000 V70XC - 300,000 miles as of 11 Aug 2020
smacknab
Year and Model: 99 s70 NA Manual
Has thanked: 73 times
Been thanked: 21 times
Post by smacknab »
"I also like to live dangerously"
Seems like you have some good suggestions here. If you haven't done this job before just make sure to check waaaay under your carpet for coolant. The top of the floorboard soundproofing foam is rubber so it's possible to miss the coolant and a couple of us have gotten burned by coolant living under there.
99 s70 NA Manual - >223k miles
Mods: Accidental C70 Delta link, V70 Left Dog Leg
smacknab
Post by smacknab »
Re: Put in a used heater core... 9144221
The Swedish car parts core is $38 through amazon via the MVS amazon link, not much more than junkyard one with lifetime warranty.
Clean thoroughly to remove oil smell before installing
TheOtherside
It got really warm before with foggy windows.
I had a friend do it and I wasn't there, so I don't know what the foam around it even looks like to say yes or no :(
98 V70R
13 Flex w/EcoBoost
