I am wondering if I need to pull the strut and flip that cross nut around . It is laying flat. Does anybody know if the cross is up or down really matters?
I was rushing the job as I am trying to finish many car repairs and projects rather than move all those parts.
Cross nut on front strut--does it matter which way?
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
the flat part goes up against the large washer. You can see the outline on the said washer. Its not possible to use the tool if its the wrong way..
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
Turbolena
- Year and Model: 850 Turbo Wagon 1994
- Has thanked: 2 times
The tool tightened it as far as it would go down, with no play...so the cross goes down against the seat, or the cross lays against the upper washer? just to clarify. Thanks
1994 850 Turbo Wagon
2006 V70R
2006 V70R
- darrylrobert
cross lays against the upper washer.
- Been thanked: 504 times
With car on the ground and spring compressed, I think you can safely remove and flip the cross nut in situ.
I use a pair of right-angle pliers...
SwedishMadeFunBrick
- Year and Model: Saffron 1998 V70R
- Has thanked: 11 times
- Been thanked: 4 times
You can do it while it's still in the car? I need to do this on my 98 v70r(mine aren't flipped,instead, for some reason I cannot figure out, I guess I decided to replace my front struts and maybe use what came with the struts? Not a cross nut just a lock nut of sorts. I hope it came with the struts at least I really don't remember).cn90 wrote: 22 May 2020, 08:29 With car on the ground and spring compressed, I think you can safely remove and flip the cross nut in situ.
Anyway, I got the cross nuts and want to install them this way but also just read that you can't do it in the car lest the shock protrude or some such.
- Has thanked: 311 times
- Been thanked: 817 times
Yes, in-car is no problem. Don't close the hood and go for a drive during the job, though
This thread talks about the top nut viewtopic.php?t=78217 but you can remove the cross nut too. Basically, the body of the car is serving as a huge, spring compressor.
- 1027 Views
Last post by erikv11
- 16 Replies
- 1207 Views
Last post by foggydogg
- 118 Replies
- 8816 Views
Last post by BlackBart
- 11 Replies
- 7938 Views
Last post by BackRoadSeeker
- 780 Views
Last post by Cookeh
