Did you know? 🤔
Radiator Fans Not Working
counselorm24
Year and Model: 1996 850
Has thanked: 10 times
Been thanked: 0
United States of America
counselorm24
Post by counselorm24 » Mon May 18, 2020 10:02 pm
Hello All,
Troubleshooting a new issue with my 1996 850. I have purchased a brand new Volvo fan controller and a brand new fan. I've finished hooking it all up tonight and the fan still won't kick on. I've tried unplugging the middle connector (ground signal to turn on relay to send power to fan) and i can hear and feel the click of the relay activating, so i assume it's getting ground from the ECU or something to turn it on. I've also verified that voltage come out of the output of the relay to go to the fans. The one thing i haven't closely traced and checked is the ground for the fan motor.
I thought about the ECT, however the temp gauge shows normal readings on the dash.
Now, assuming that the ground tests out OK and a bypass doesn't engage the fan, Does anyone have any advise of what to do or look for next?
Thank You,
Michael
ZionXIX
Has thanked: 9 times
Been thanked: 40 times
ZionXIX
Re: Radiator Fans Not Working
Post by ZionXIX » Mon May 18, 2020 10:27 pm
Have you tried powering the fan directly from the 12v system? Is your coolant temp sensor good?
counselorm24
Been thanked: 0
counselorm24
Post by counselorm24 » Tue May 19, 2020 9:33 am
The fan does function when hooked up to the battery direct. I am assuming the coolant temp sensor if good, as I show accurate temp reading on the temp gauge. Is there still a possibility this sensor could be bad? If so i can change it out, not to mention, i can tell the relay is clicking on with a signal from the ECU, so the issue might lie in the power supply to the relay/fan or the ground.
Is there a fuse or relay for the fans? If so, where are they located?
Also I think my voltage when the car is running might be slightly low, could this be causing the issue as well?
I will have it checked by the local AutoZone when i get out of work, I think the alternator has been recently replaced, so I might replace some old wires to/from the unit.
When the relay or fan is disconnected from any of the wires and plugged back in when the car is running and up to temp. I will see the fan jerk slightly, but never spins.
Thanks
Mike
Has thanked: 11 times
Been thanked: 207 times
Canada
Post by scot850 » Tue May 19, 2020 10:42 am
The connector to the fan from the ECT is notorious for issues. The connector for the ECT is normally mounted at the back of the power steering pump. The wire from there to the operate the the fan and relay may have a bad connection at this point or may be broken. So check the continuity from the connector on the power steering pump to the relay.
The ECT itself may be reading just fine otherwise in the car. It is just the signal wire to the fan that is the problem.
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
Azik09
Year and Model: S70 T5, 1997
Has thanked: 0
Been thanked: 3 times
Russia
Azik09
Post by Azik09 » Tue May 19, 2020 11:12 am
Check fan's ground. If relay have not powered, you couldn't hear click when connect any of middle pins to ground. Fan is grounded to cylinder block near starter motor by separate black wire.
Simple fan test: disconnect ECT and start the engine. Fan should start immediately. If so, all fan's circuits are OK
If my English is bad, please correct me :oops:
counselorm24
Been thanked: 0
counselorm24
Post by counselorm24 » Tue May 19, 2020 11:29 am
Sounds good!
I'll test the ground and ECT and let you know the results.
Thank You
Mike
counselorm24
Been thanked: 0
counselorm24
Post by counselorm24 » Tue May 19, 2020 5:59 pm
Hello All,
I've tested the power and ground to the relay and it is good, I've also applied the ground to the two relay control pins and get good high and low speed operation.
I've hooked it all back up, started the car and turned on the AC full blast but no fan operation.
When I unplug the ECT, the fans kick right on high, but the car also runs worse, and I still have normal temp readings. Is there another temp sensor somewhere?
When I plugged the ECT back in the car runs better, and I'm getting low speed fan operation. Maybe a bad connection on the ECT?
I've ordered a new ECT anyhow.
Let me know what you all think
Thanks for the info!
Mike
PS: Can someone send a picture of the wire color vs it's position in the middle connector of the fan relay? I removed them to clean them, but forgot to keep track of where they went. :roll:
Azik09
Has thanked: 0
Russia
Azik09
Post by Azik09 » Wed May 20, 2020 12:00 am
Looks like ECT is defective...
There is only one temp sensor.
Fan relay middle connector: pin#1 - yellow/white
pin#2 - yellow
These users thanked the author Azik09 for the post:
counselorm24
Chuck W
Year and Model: 97 854 T5
Has thanked: 19 times
Been thanked: 38 times
Chuck W
Post by Chuck W » Wed May 20, 2020 3:20 pm
Clean that ECT connector.
counselorm24
Been thanked: 0
counselorm24
Post by counselorm24 » Fri May 22, 2020 9:55 am
Hello All,
The new ECT is on it's way in today. I'll clean the car side connector before installing it and let you all know how it goes.
Thanks for all the suggestions!
Mike
