Did you know? 🤔
2003 V70 T5 Key Swap
2001 - 2007 XC-70
Mountainman45
Year and Model: 01 V70XC
Has thanked: 1 time
United States of America
Mountainman45
Post by Mountainman45 » Wed May 20, 2020 1:29 pm
So I'm at a loss. I have a 2003 V70 T5 that has been sitting for close to 2yrs. Somewhere along the way the original keys were lost and being the broke student I am, I decided to get resourceful rather than go to Volvo for $400 worth of new keys and programming.
I went to my local junk yard and found a door lock, ignition lock and key for $20. Knowing Volvo and their anti-theft systems, I also grabbed the antenna ring around the ignition switch. Now, I finally got everything installed (NOT EASY TO DO) and went to turn the key and not so much as a clicking starter. Unfortunately, the previous owner (my father) tried swapping a R cluster into it and I found out that the little message area in the bottom left corner doesn't work. So I can't even tell if its the immobilizer. I also don't know how to reset the immobilizer without a key fob
Long story short... I'm wondering if there's another piece to the anti theft system that I didn't grab. Something specific to each car??
Has thanked: 316 times
Been thanked: 981 times
Trinidad & Tobago
Re: Key Swap
Post by abscate » Wed May 20, 2020 4:37 pm
Inside the key Is an RF chip which will only work with an ECU that is programmed to accept it.
From 1999 on, you need VIDA and a server connection to program an ECU to accept a key.
Losing a key on a Volvo is a painful, expensive lesson
Link To Volvo Glossary
Mountainman45
Has thanked: 1 time
Mountainman45
Re: Key Swap
Post by Mountainman45 » Wed May 20, 2020 6:58 pm
Oh I have access to people with Vida. It's not the worst thing in the world. I also PERSONALLY have access to a Snap-On Verus Diagnostic Center at work. (Can read as many things as Vida if not more) I should be able to program it tomorrow at work.
Now sightly off topic, the instrument cluster.... Do I also need Vida to mate it to the car?
- Pete -
Has thanked: 55 times
Been thanked: 77 times
- Pete -
Re: Key Swap
Post by - Pete - » Wed May 20, 2020 7:19 pm
Member Yagger does this sort of work very regularly & his rates are very affordable. He doesn’t post much, so maybe send him a PM.
2001 V70XC 146k
2004 V70 AWD 141k
2004 V70R M66 144k
2004 XC70 287k
2006 XC70 155k Sold
vtl
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 63 times
vtl
Re: Key Swap
Post by vtl » Wed May 20, 2020 10:25 pm
You need all of: VIDA Online active subscription, new (empty) key, bar code sticker from the packet with the key. The immobilizer chip is programmed once, after that it can't be reprogrammed.
05 XC70 260k, 16 XC60 40k, 19 Tundra 1k
darrylrobert
Year and Model: 2001 v70xc
Been thanked: 7 times
Australia
darrylrobert
Re: 2003 V70 T5 Key Swap
Post by darrylrobert » Fri May 22, 2020 3:55 am
I hope you have better luck than me, i emailed a few key cutting places that say they do Volvo keys/RFID programming but no reply after 1 week. I have bought two P2 cars and with each car only given one key. I think the RFID chips in many keys stopped working. Its an expensive trip to the dealer if you cant get anyone online to do it.
Trinidad & Tobago
Post by abscate » Fri May 22, 2020 4:53 am
They key is about $50 programmed at a good independent with VIDA AND SERVER subscription.
The fob is more expensive
darrylrobert
Australia
darrylrobert
Post by darrylrobert » Fri May 22, 2020 8:46 pm
For anyone wanting the "R" blue facia cluster look to replace your standard DIM, the best way is to take apart your original working DIM and remove/swap the gauges, it should work. If it doesnt remove the gauge needle and replace the facia (it peels off ).
It may be possible to buy the facia aftermarket?
r face cluster
