I have a leak between the two halves of the thermostat assembly on a 2004 V70, and as the car is at 186K, I figured I'd replace the thermostat and the gasket both. But no one seems to sell the gasket that marries the top half to the bottom.
Amazingly, for $20, both Parts Geek and carparts.com have this assembly with the brand name "Replacement". The whole shebang - base gasket, thermo, body, sensor, the works. Is this thing junk, or not? Best price otherwise is $80+
Stop me before I make a choice I'd regret.
"Replacement" Brand V70 Thermostat Assy for $20?
- packetfire
- Year and Model: 2010 v50 2.4i
- Has thanked: 17 times
- Been thanked: 30 times
1982 240DL: Drove it 32 years and 1.5 million miles (sold, even still had mint leather!)
2001 v70 2.4T: The most expensive $1500 car I ever bought ("Volvo Turbo" - what an oxymoron!) (sold)
2004 v70: Far less fatally-flawed v70 - It served well (sold)
2010 v50: Smaller, slightly sportier wagon. Its got a spoiler, so I upgraded with sway bars!
- GlennG2759
- Year and Model: 2006 V70 NA
- Has thanked: 112 times
- Been thanked: 17 times
I believe most people here would probably recommend genuine Volvo on this part because of the sensor, but I have had the Facet thermostat assembly (around $80) from FCP in my V70 for about 8 mos. now with no problem, don't think I'd trust this part for $20.Good Luck
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
Excellent advice. Don’t fool around with something so important. It is very tempting & I am guilty of succumbing to this sort of temptation!
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
The $20 one is very suspect, they also sell a water pump with $20. I imagine these are disposable parts meant to last a few months. You can make a gasket with Permatex, just scrap the old gasket and clean the surface, use only a thin coat and follow the exact instructions on the tube. As for the thermostat itself, it's not sold separately but you may manage to use one for the Volvo S60 D5 diesel engines
- Been thanked: 504 times
Buy Wahler for $90.
Remove the upper housing + gasket + thermostat itself and transfer them over w/o the need to remove the PS pump.
Info in XC90 forum (I wrote the tricks there).
- oragex
Also keep the old coolant temp sensor for spare
- 1081 Views
Last post by cn90
- 1079 Views
Last post by Georgeandkira
- 846 Views
Last post by V50M66
- 1266 Views
Last post by shlowsby007
- 779 Views
Last post by rguzz
