08 C30 - Engine turns over with constant "grinding" no start
Smax
Year and Model: 2008 C30
Post by Smax »
I am stumped and needing help!
I changed the plugs on my C30 as a maintenance issue and went to start it after and it wouldn't turn over normally. All it does is a slowish turnover at a constant speed and almost sounds like a grinding type noise. It continued until it timed out. Tried again and same thing. I put old plugs back in that were working prior and same issue. Checked for spark at sane time and it is getting spark.
I was having an issue awhile back where I'd have to turn the key on twice to start the car so thought perhaps Starter. I replaced starter and solenoid and still having the same problem.
Here is a link to a video showing it. I had the timing belt cover off and prior and could see the engine is actually turning over slowly as this is happening.
Thanks
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
Check the battery, Battery cables and clean the battery terminals.
Active
Past
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Did you accidentally allow something down into a spark plug hole?
Also -> Amazon link
Smax
Post by Smax »
Battery and everything checked and good. When I took out one of the spark plugs it did break however was able to retrieve broken piece that matched up so all good.
As an aside, I don't think it did but if a tiny shard of spark plug ceramic did fall in to hole would it cause this?
Thanks
