Did you know? 🤔
08 C30 - Engine turns over with constant "grinding" no start
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
Smax
Year and Model: 2008 C30
Has thanked: 0
Been thanked: 0
Canada
Smax
Post by Smax » Fri May 22, 2020 9:53 am
I am stumped and needing help!
I changed the plugs on my C30 as a maintenance issue and went to start it after and it wouldn't turn over normally. All it does is a slowish turnover at a constant speed and almost sounds like a grinding type noise. It continued until it timed out. Tried again and same thing. I put old plugs back in that were working prior and same issue. Checked for spark at sane time and it is getting spark.
I was having an issue awhile back where I'd have to turn the key on twice to start the car so thought perhaps Starter. I replaced starter and solenoid and still having the same problem.
Here is a link to a video showing it. I had the timing belt cover off and prior and could see the engine is actually turning over slowly as this is happening.
Thanks
RickHaleParker
Has thanked: 3 times
Been thanked: 536 times
United States of America
RickHaleParker
Re: 08 C30 - Engine turns over with constant "grinding" no start
Post by RickHaleParker » Fri May 22, 2020 1:59 pm
Check the battery, Battery cables and clean the battery terminals.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger, Plant Ghent Belgium.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 566 times
Been thanked: 218 times
matthew1
Post by matthew1 » Fri May 22, 2020 2:07 pm
Did you accidentally allow something down into a spark plug hole?
Also -> Amazon link
. Click that when you go to buy something on Amazon and MVS gets a kickback.
1997 850 T5, MSD ignition coil, Hallman manual boost controller, injectors, R bumper, OMP strut brace [gone]
Smax
Has thanked: 0
Been thanked: 0
Canada
Smax
Post by Smax » Fri May 22, 2020 7:27 pm
Battery and everything checked and good. When I took out one of the spark plugs it did break however was able to retrieve broken piece that matched up so all good.
As an aside, I don't think it did but if a tiny shard of spark plug ceramic did fall in to hole would it cause this?
Thanks
