How can an engine code clear itself?
- SuperHerman
- Been thanked: 207 times
Basically codes are of three types 1) Actual part has failed (code will not clear until part/sensor replaced); 2) intermittent failing part (code will come and go); or 3) code caused by the computer reading an issue which has resolved itself.
Possible causes for a generic P1235 code are: Faulty Fuel Pump or related module; sensor or related wiring is open or shorted; bad wiring in the circuit, or another faulty module
Your issue could be either 2 or 3 - maybe bad gas or some debris in an injector that was cleared via use. I would keep an eye on it and see if it comes back. One thing about generic codes (not VIDA or Volvo scanner specific) is many false codes.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
I believe every car should have a drive cycle where the computer checks for faults. As Super says if the computer sees that the reading is Okay it will remove the light / fault code.
- ndphotonl
- Year and Model: 2001 S80 2.4T
- Has thanked: 27 times
- Been thanked: 33 times
If you check it with DICE, it will probably still be referenced over there. Not all codes are visible with something like Torque Pro app or a universal code reader.
Volvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
FlickR images
- 1524 Views
Last post by SuperHerman
- 1582 Views
Last post by lext
- 1584 Views
Last post by alschnertz
- 1363 Views
Last post by michael8888
- 4529 Views
Last post by RickHaleParker
