Did you know? 🤔
99+ PCV question
ThePluralofMoose
Year and Model: 1999 s70 NA
Has thanked: 3 times
Been thanked: 0
United States of America
ThePluralofMoose
99+ PCV question
Post by ThePluralofMoose » Sun May 24, 2020 10:13 am
Hi all- I’ve done two PCV Jobs on ‘98 s70’s— both we’re turbo models. I’m preparing for the job on both my ‘99 NA s70’s and had one question:
Is it true that you can remove the PCV breather box with out taking the intake manifold off in the ‘99 and newer cars? I believe that I read this at one point but can’t find any supporting anecdotes or literature which would point to that. By looking at it visually it looks like it’s possible to do with the right extensions for the bolts that bracket the breather in place.
Thanks in advance!
___________________________________
NY,
Valkyrie: 1999 S70 N/A, (Belgium), 113K, two tone taupe leather, black rhino-skin exterior, no carpet, no back seats :twisted:
Heidi: 1999 S70 N/A, (Sweden), 247k,
beige leather, Natuic Blue, factory tints, :mrgreen:
Previous: Freyja: 1998 s70 t5, (Belgium), 208k, Black Alcantara and light woodgrain,
Blown trans and tc, :oops:
Has thanked: 333 times
Been thanked: 1035 times
Trinidad & Tobago
Re: 99+ PCV question
Post by abscate » Sun May 24, 2020 4:12 pm
That would be near impossible, and certainly not advisable
These users thanked the author abscate for the post:
ThePluralofMoose
Link To Volvo Glossary
Has thanked: 12 times
Been thanked: 230 times
Canada
Post by scot850 » Mon May 25, 2020 11:28 am
It may be possible, but difficult. As the NA has the Denso throttle body to the side of the intake and not under it you will have some room under there. However as abscate says it will be hard to do even in that case. On a Turbo I wouldn't even consider it. Being able to see the block drains is also an important requirement.
On my old 00 V70 NA I did the full remove, but part of the reason was to get access to the PCV pipes to clean, check and inspect them. Also I had another leak in that area that needed to be found.
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
ThePluralofMoose
Been thanked: 0
ThePluralofMoose
Post by ThePluralofMoose » Mon May 25, 2020 12:54 pm
Abscate thanks again—
Neil appreciate the input. My fears lie in removing anything related to the ETM on these 99+ cars while they’re in working order. On a ‘98 I can do the full remove and replace in no time at all. Both engines are passing the glove test right now and I change oil every 4K religiously. However there’s some serious staining under the breather on my new ‘99 so it’s probably needing to be done ASAP. The worst of it thus far on my daily is losing about a quart of oil every 5kish. There’s also a chance the gasket on my oil pan is going. Coming up on 40K under my ownership and this would be the first major work I’m giving the car besides timing which I did at 100k so I’m not too bothered.
NY,
Trinidad & Tobago
Post by abscate » Mon May 25, 2020 2:59 pm
Don’t sweat your NA ETM. Four bolts, then put it into a nice clean plastic bag, you don’t even need to disconnect the plug. It should be squeaky clean, though. Be careful with solvent, wipe throttle with moist cloth.
I wonder if my V70 back seat would fit Valkyrie?
Canada
Post by scot850 » Mon May 25, 2020 7:00 pm
Like abscate says. Again if it was a turbo ETM then it is possibly a worry, but not on an NA. It is possibly as easy as a 98 NA. Wiping as abscate mentioned with a dampened cloth with cleaner on the throttle body is the way to go. Don't spray it at all.
These users thanked the author scot850 for the post:
ThePluralofMoose
2006 XC70
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 44 times
Been thanked: 158 times
bmdubya1198
Post by bmdubya1198 » Mon May 25, 2020 10:19 pm
Dampened with brake cleaner for some cutting power. But definitely don't spray it directly, too risky.
Anyway, I don't think it's possible to get the oil trap out with the intake manifold in place. If the ETM was out on a turbo manifold, you MIGHT be able to pull it off, but I doubt it. I managed to replace the top PCV hose without removing the manifold, but that's easy to get to if you reach under.
2000 V70R Venetian Red/Charcoal M56 Swapped 197k
2003 S60 2.4T Silver/Black 113k
2007 XC90 V8 AWD Sport Titanium Grey/Black 171k
1991 944 Turbo Dark Green/Beige 174k
1992 245 Base White/Beige 249k
2006 BMW 330i
1999 BMW 528i
2000 S70 GLT Mystic Silver/Taupe 253k
1993 944 Base Beige/Beige 221k
1998 V70 GLT Black/Beige 199k
1998 S90- Silver/Gray 207k
1995 850 GLT Tropic Green... crushed
2001 S60 2.4T Black/Black 230k
1988 744 Turbo M46 Beige Metallic/Beige 188k
