How do my Delta Link Bushings look to you?
jonslave
Year and Model: 1997 855R
Has thanked: 12 times
Post by jonslave »
Car has a lot of miles on it. How do these look guys?
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
The rubber looks a little old, but they appear to actually be in one piece.
Unless they are broken, or your in replacing the outer link bushings, I would just leave them.
Has thanked: 2199 times
Been thanked: 1851 times
+1 First one looks ok, but second one is starting to get there but not yet.
jonslave
Post by jonslave »
Did them both and the delta links. Woof. Not a fun one.
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
wow, that was quick!
1996 855 R,
2010 V70 D5,
my98s70glt
Year and Model: 99 V70R, 07 V70 2.5T
Has thanked: 11 times
Been thanked: 5 times
Post by my98s70glt »
Heat is your friend. I was told to blast the delta link with heat until the plastic shell starts to melt then it should slide out a lot easier. Unfortunately, that knowledge was dropped on me after the fact.
Current:
1999 V70R: Signal Red/Charcoal || Snabb RIP Kit || Snabb Air Intake || Simons Axleback Dual Exhaust
2007 V70 2.5T: Snabb Fresh Air Pipe || BC Racing Coilovers
Previous: 1998 S70 GLT, 2006 V70 2.5T, 2011 C70 T5, 2012 S60 T5, 2000 S70 GLT/SE
jonslave
Post by jonslave »
I just raked a drill across the top and plunged it in the corners a few times. Popped right out with the tool.
For the Delta link bushings, I actually ended up lowering the whole rear suspension to the ground with the brake rotors sitting on wood blocks. Just didn't have 2 wheeled jacks. Shocks disconnected but springs in the seats. I HIGHLY recommend having 2 rolling jacks under the spring seats. If you don't, be prepared to muscle the assembly around.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Just curious - where did you find the delta link removal tool ?
1999 V70 GLT
jonslave
Post by jonslave »
A seller on ebay had the genuine volvo one
Sveedy
Post by Sveedy »
Good find and impressively done !
1999 V70 GLT
