Did you know? 🤔
98 XC Power steering fluid preferences
CIK7
Year and Model: 1998 Volvo V70 XC
Has thanked: 68 times
Been thanked: 3 times
United States of America
CIK7
Post by CIK7 » Tue May 26, 2020 2:03 pm
I read a thread about power steering fluid on here. I have to replace the pump because it somehow got damaged during my accident on may 2nd. The manual states Volvo ATF only. The thread I read said (haha) Mobil 1 dexIII. The manual also says Volvo ATF for the transmission. A preference for a couple people out there is the Toyota TIV ATF. Can I use Toyota TIV in the power steering with no issues? How much fluid does the power steering need? I found a good deal on it. I need to drain and refill the transmission too.
1998 V70 XC black ($1K trade, Mi:143,995/151K, immaculate engine, totalled 5/2/20)
1998 V70 XC white ($50 cash, junk, donor for my black XC)
2001 V70 Ba white (sold)
2009 Impala LT 3.5L (sold)
Plans for my 98 XC: 16T/18T, P2 M66 swap, logo/badge delete excl grille
misha
Has thanked: 57 times
Been thanked: 144 times
Serbia
misha
Re: 98 XC Power steering fluid preferences
Post by misha » Tue May 26, 2020 2:04 pm
Just regular red ATF...1l is enough for power steering.
These users thanked the author misha for the post:
CIK7
'91 Citroen XM 2.0 SI /fully equipped/mandarine red metallic
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 12 times
Been thanked: 230 times
Canada
Post by scot850 » Tue May 26, 2020 2:50 pm
The Toyota TIV is an Aisin product equivlant to the 3309 ATF and not the Dex3.
I believe you can also use the Volvo Pentisin fluid but you cannot mix it with ATF.
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
CIK7
CIK7
Post by CIK7 » Tue May 26, 2020 4:06 pm
scot850 wrote: ↑
Thank you. The Volvo parts dept at dealer said DOT 3 power steering fluid should work. Is this true?
CIK7
CIK7
Post by CIK7 » Tue May 26, 2020 4:07 pm
The parts dept at Volvo dealer said DOT 3 ps fluid should work. True or not true?
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 33 times
Been thanked: 70 times
MoVolvos
Post by MoVolvos » Tue May 26, 2020 4:23 pm
CIK7 wrote: ↑
No one uses the term DOT 3 for transmission fluid. The term is used for brake fluids DOT 3, DOT 4 or both. The 98's should use DEX III.
I've used Havoline (EDIT: Full Synthetic Multi-Vehicle ATF) in the following for full flushes:
03 Lexus GS300 - Transmission, Powersteering
03 S80 T6 - Transmission, Powersteering
03 Odyssey - Transmission (Honda says their Fluid Only), Original Transmission w/230K
https://www.amazon.com/HAVOLINE-2265364 ... 214&sr=8-1
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
CIK7
CIK7
Post by CIK7 » Tue May 26, 2020 4:37 pm
MoVolvos wrote: ↑
CIK7 wrote: ↑
I've used Havoline 3309 in the following for full flushes:
No I'm referring to power steering fluid, not ATF.
misha
Serbia
misha
Post by misha » Tue May 26, 2020 4:43 pm
CIK7 wrote: ↑
Should work????
NOT TRUE!
Don't go to them and don't listen to them!
Owners manual says ATF(red) for power steering.
Later models use Pentosin,which can also be used in P80 BUT you MUST flush power steering system first... because they are not compatible.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
MoVolvos
MoVolvos
Post by MoVolvos » Tue May 26, 2020 4:49 pm
CIK7 wrote: ↑
I believe the 98 calls for DEX III (transmission fluid) in the powersteering so the Havoline covers the DEX III (EDIT: which is) for the transmission also.
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
MoVolvos
MoVolvos
Post by MoVolvos » Tue May 26, 2020 4:55 pm
I use to have a 98 S70 T5 which was purchased with around 230K miles. Used DEX III compatible transmission fluid and flushed twiced without issues. It was coffee colored and after 1 year flushed again with no issues. In 2012 used a turkey baster to removed the old powersteering fluid, circulate and removed till is was clean. This is before seeing the video above.
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
