Did you know? 🤔
Since we're talking about Air Conditioning shims with bread clips and wire ties....
2001 - 2007 XC-70
Jonboy74
Year and Model: V70 2.4T, 2002
Has thanked: 54 times
Been thanked: 6 times
United States of America
Jonboy74
Post by Jonboy74 » Sun May 31, 2020 9:51 pm
I'm curious, for those of you who have done this, how long has it lasted before you finally gave up and shelled out for a new compressor or clutch?
viewtopic.php?f=1&t=31203
I did this a couple of years back and this season it started acting up again....
I dove in and put in a couple more cable ties and it seems to be working....but I literally just did it yesterday, and it wasn't hot out today, so....
Thanks,
Jonboy
2002 V70 2.4T
Something north of 260k miles....
Has thanked: 328 times
Been thanked: 1032 times
Trinidad & Tobago
Re: Since we're talking about Air Conditioning shims with bread clips and wire ties....
Post by abscate » Mon Jun 01, 2020 3:47 am
Mine lasted 5 years and about 70,000 miles more before the clutch plate gave up and fragmented. I think there are role here with even longer reported success
These users thanked the author abscate for the post:
Jonboy74
Link To Volvo Glossary
amblerman
Year and Model: 1999 s70
Has thanked: 1 time
Been thanked: 38 times
amblerman
Post by amblerman » Mon Jun 01, 2020 6:59 am
Mine lasted two years.
When I took a look, the bread clips were gone.
Instead of moving to the zip tie method (which should hold nicely), I just took clutch plate off and replaced shims inside clutch.
That as last year. Haven't even tried things this year to see if the AC works.. Just driving so little
These users thanked the author amblerman for the post:
Jonboy74
Trinidad & Tobago
Post by abscate » Mon Jun 01, 2020 7:06 am
If anyone needs shims I bought a bunch on one of my FCP orders - I can mail for a stamp vs $9 shopping for a 90 cent part.
I could also give dimensions as any steel washer would do here.
Jonboy74
oragex
Year and Model: S60 2003
Has thanked: 97 times
Been thanked: 275 times
Canada
oragex
Post by oragex » Mon Jun 01, 2020 11:21 am
The gap wasn't bad yet, but the bearing on my pulley was making noise at 100K miles, so I went replacing the bearing (with a quality one) and in the process you can remove a shim to adjust the gap (there's 3 shims of different thickness inside). Now at 135K miles, being fine ever since www.youtube.com/watch?v=KAGDkwYSFY4
These users thanked the author oragex for the post:
Jonboy74
kallekula
Year and Model: S70 2000
Has thanked: 20 times
Been thanked: 21 times
kallekula
Post by kallekula » Mon Jun 01, 2020 11:26 am
my zips has been holding up for at least a couple of years. more like 3-4 I think. And I bought them at HF! :shock:
These users thanked the author kallekula for the post (total 2):
abscateJonboy74
BMW 540i 2002
S70 Base 2000
S40 T5 2004.5 (For Sale)
Has thanked: 99 times
Been thanked: 293 times
Post by erikv11 » Mon Jun 01, 2020 10:05 pm
I have zip tied three P80 car compressors, all are still holding. Longest is past 5 years by now, based on my posts over in that other thread.
These users thanked the author erikv11 for the post:
Jonboy74
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 286k
'06 S60 R, 167k
'99 Camry V6 :shock: 125k
RichCrewe
Year and Model: S60 2002
Has thanked: 0
Great Britain
RichCrewe
Post by RichCrewe » Tue Jun 02, 2020 2:39 pm
I did the zip-tie fix in 2012, still working (though the UK isn't really the most punishing environment for an air-con system.) I did find that I got the same symptoms as a worn air-con compressor clutch (air-con cutting out and not re-engaging without a "rest") when the alternator was failing. I guess when there's low-ish battery voltage, the air-con is the first thing to be switched-off.
These users thanked the author RichCrewe for the post:
Jonboy74
Jonboy74
Jonboy74
Post by Jonboy74 » Fri Jun 05, 2020 6:12 am
Fair enough. So, I might be good for a couple more years (I'm in North Carolina and its been in the 80's the past few days - brutal days are ahead, temperature-wise). Seems to be holding for now, nice and cool.
I figured (maybe incorrectly?) that in order to replace the clutch plate that I would have to remove the compressor from the system, breaking the seal, and it wouldn't be worth it...but (I'm not looking for trouble) if/when the time comes, can it be done without opening the system? I figure if I have to break the seal, then I might as well either replace the AC components altogether or junk the car....because the car isn't worth more than a couple thou....
As a reminder, we're talking about a 2002 V70 2.4T - there's barely enough room to get my fingers down around the clutch plate, and only because I have skinny arms, LOL.
Thanks!
Jonboy
Trinidad & Tobago
Post by abscate » Fri Jun 05, 2020 7:30 am
You can ease the compressor off the bracket and create enough space to work on the clutch and do the “ correct fix’ , if you think you want to run the car for 5 I think that is what I would do.
On edit...Easing the compressor back means you do not break the AC lines , so no need to evacuate, pump down, and recharge. You can get a sense of the clearance in peppermint’s video
I was getting ready to do this on my T5 when the clutch nicely grenadednand the compressor started growling, so I did a new compressor. Always a struggle spending for a new part when you wonder how much life the car had, but I will say I could not remember the compressor price yesterday cruising the interstate at 90F with 68F air inside
G’noght J,
Elizabeth
