Did you know? 🤔
High-Pitch Whine on Right-Hand Side when Driving
efkaba
Year and Model: 850, 1995
Has thanked: 1 time
Been thanked: 0
United States of America
efkaba
Post by efkaba » Mon Jun 01, 2020 12:03 pm
Hello All,
I have a 1995 850 GLT 4-door sedan. Been noticing a very high-pitched whine coming from the right-hand side of the car while driving. The best way to describe the sound is that it sounds like a Dremel Tool, or maybe a small air sander. It sounds like it's coming from the axle, but can't be sure. Wheel bearing seems to be OK, I can't detect any looseness or or play, and nothing appears to be wrong with the axle or carrier bearing. This is a replacement axle I purchased from FCP Euro, and installed in 2014. Has anyone else ever encountered this problem, and if so, what was the fix. Thank you in advance for any help.
Has thanked: 328 times
Been thanked: 1032 times
Trinidad & Tobago
Re: High-Pitch Whine on Right-Hand Side when Driving
Post by abscate » Mon Jun 01, 2020 12:40 pm
Does it change under load, turning, acceleration, deceleration - and can you try turning the engine off on a lonely road to see if it is car or engine noise?
Wheel bearings usually growl, not whine, and axles clunk.
Link To Volvo Glossary
efkaba
Has thanked: 1 time
Been thanked: 0
efkaba
Post by efkaba » Mon Jun 01, 2020 1:02 pm
The pitch gets higher when accelerating, lower when decelerating and doesn't change when turning. It is definitely a car noise, not an engine noise. I put the front of the car on jack stands and ran it in gear. Noise was coming from the right, and only while the right wheel was spinning. Never heard anything like this noise before; I've heard noise coming from wheel bearings that were about to fail, and the clicking/clunking noises from a failing axle joint. It doesn't sound like it's coming from the transmission. It almost sounds like something metallic is rubbing, but can't see anything rubbing against the axle.
Thanks
Has thanked: 12 times
Been thanked: 230 times
Canada
Post by scot850 » Mon Jun 01, 2020 4:31 pm
Check the brake rotor dust shield has not been bent onto the rotor. It is a fairly common issue if it gets knocked as it is fairly lightweight. It can be bent back away from the rotor easily.
The only other thing on the right side I can think of is the extra axle support bearing between the transmission and the CV joint.
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
efkaba
Has thanked: 1 time
Been thanked: 0
efkaba
Post by efkaba » Mon Jun 01, 2020 6:27 pm
Neil,
Thanks! I didn't see any problems with the dust shield, but I will recheck. My thoughts were the support bearing also, but I don't feel any play or anything abnormal with it. The noise does seem to be coming from the axle, but I don't want to replace the axle if it turns out that isn't the problem. Also, I don't think it's a transmission problem. So, I will take a second look at the dust shield.
Thanks, Ed
Has thanked: 99 times
Been thanked: 293 times
Post by erikv11 » Tue Jun 02, 2020 7:46 am
Given all your descriptions and the fact that it is a 6 year old replacement axle - 10:1 the axle is the problem. Be grateful you got 6 years from it!
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 286k
'06 S60 R, 167k
'99 Camry V6 :shock: 125k
efkaba
Has thanked: 1 time
Been thanked: 0
efkaba
Post by efkaba » Tue Jun 02, 2020 9:09 am
Thanks, I agree, I am now 99.9% sure it's the support bearing.
Canada
Post by scot850 » Tue Jun 02, 2020 10:08 am
I have had a few axles where the bearing seemed fine but they were dry and noisy. It is possible to replace the bearing with the axle removed. Volvo still list a bearing for the 98 and older cars. It is expensive though! I bought a Ford Transit bearing for $10 US from Turkey via a link from abscate a few years ago. It was harder to remove and fit as the axle had some welds that were in the way but careful grinding sorted that. I fitted the new bearing using a length of metal fence post with a metal cap on it.
Removing the old one the dealer did it for me, but I have seen people removing it by breaking it with a cold chisel.
2006 XC70
efkaba
Has thanked: 1 time
Been thanked: 0
efkaba
Post by efkaba » Tue Jun 02, 2020 7:28 pm
Thanks! I'll check that out. I'm sure it is the support bearing.
Trinidad & Tobago
Post by abscate » Wed Jun 03, 2020 3:52 am
Have you tried injecting grease into it with a needle to see if the noise changes?
This is a rare failure but one with which I have always been intrigued about repair.
( We dangle mufflers here on MVS, But never prepositions.)
