Broken vacuum line?
- Has thanked: 311 times
- Been thanked: 817 times
That one connects to the TCV, to the straight nipple on the end with the two nipples. I'd wholesale review all of the vacuum lines.
EVAP code is probably one of the other, 22 year old vac lines has crumbled or has a pinhole etc. Likely unrelated.
That current open line is allowing unmetered air into the intake past the MAF, so the engine is running lean (very bad) or the ECU is compensating and it is running rich (less bad but still undesirable).
Frankly I would plan to replace all of the vacuum lines. But start with re-plumbing the TCV lines, go from there.
- RickHaleParker
- Been thanked: 979 times
Take the big air hose off. You will find the other end of the small hose below and near the back of the head.
Active
Past
Past
You think this goes back to the FPR? I think it's to the TCV ...RickHaleParker wrote: 03 Jun 2020, 20:49 Take the big air hose off. You will find the other end of the small hose below and near the back of the head.
JLv70t5
- Year and Model: 1998 v70t5
- Has thanked: 11 times
If I'm not mistaken the tcv (turbo control valve) is the same a the bcs (boost control solenoid) wich is the part a just replaced. Definitely not to that. What's the fpr?
JLv70t5
I found this forumerikv11 wrote: 03 Jun 2020, 20:55You think this goes back to the FPR? I think it's to the TCV ...RickHaleParker wrote: 03 Jun 2020, 20:49 Take the big air hose off. You will find the other end of the small hose below and near the back of the head.
viewtopic.php?f=1&p=276263#p276263
This is definitely it. Thanks for the help
- RickHaleParker
I just took a quick look at my "98 C70 to see where the line is heading.
The other end terminates at a air pipe. Nipple at the metal pipe.
Active
Past
Past
FPR it is!
- 1638 Views
Last post by cn90
- 3513 Views
- 924 Views
Last post by EstVolvo
- 60 Replies
- 8083 Views
Last post by ericmci
- 2356 Views
Last post by Centex Swede
