Rear seat V70 2009
- RickHaleParker
- Been thanked: 979 times
Push back on the seat and compress the seat to unhook the front of seat from the body. Sometimes you got to push pretty hard. You might slide the front seat all the way forward. Then have a strong little guy get on the floor and push with his legs. There are two hook points one each side.
Active
Past
Past
Steve H
- Year and Model: 2008 S60 2.5T & XC70
- Has thanked: 6 times
- Been thanked: 10 times
Does it have the built in child booster on the rear seat? If so, with the child seat up look at the surface under where it folds back in at the corner for a Velcro section in the corner that you pull away to expose the bolts on each side.
