Ok so here’s what’s going on. Started loosing fuel pressure after fixing a stuck float on the pump side of the tank. Got a code for the fuel rail pressure sensor. Changed it out ran great for a few days. Symptoms came back, so I figured what the hell. Let’s change the pem too. Yay fuel pressure normal runs great! Now all of a sudden I have no communication with the ecm, tcm, bcm, and sas modules. I have no broken wires, while doing a basic canbus test 2.7v on the high side, 2.3v to the low side and 60ohms while the vehicle is in pos 2. Now as soon as I start the car, it idles and runs all day perfectly as long as I am moving. If I start it and let idle for a few minutes, the gear indicator goes from P to - in the display. This tells me bad tcm, as the codes in vida correlate that. But it’s also saying lost comm with ecm as well. So I put a used ecm in (not expecting to be able to start it cause of wrong software) and I still have no communication with the above modules. Anyone got any ideas?
The is an 08 xc90 3.2l non turbo, fwd.
08 xc90 lost canbus? Topic is solved
- 2000c70hpt
- Year and Model: 2000 C70
- Has thanked: 1 time
- Been thanked: 8 times
2000 C70 hpt with 140k
2008 xc90 t6 non turbo with 170k
- 2000c70hpt
Forgot to mention. I do have vida dice
- yagger
- Year and Model: V60 2016
- Has thanked: 6 times
- Been thanked: 39 times
In ideal case, you have to use oscilloscope for check signal on CAN bus.
But, you can start from:
check top connectors on CEM for water damages,
disconnect DEM connector for confirm DEM is ok or no.
Volvo electronic expert
Online Data Transferring Service for Volvo modules
- 2000c70hpt
No water on the cem as I’ve already had it out looking for corrosion and popped surface mount components. Dem? Do you mean the dim? Driver info module? Checked it. The only oddity I’ve noticed was a 10 mile discrepancy between the dim and vida.
- 2000c70hpt
My vehicle is not equipped with that module. It's only front wheel
On a side note i put the original pem back in since my issues I think started after the change
- 2000c70hpt
Well a little update. I reinstalled the original pem and regained communication with the rest of the modules. Though I’m have fuel pressure issues again. From cold start it runs great. This morning I even let it idle for 30 minutes and then took it for a drive and ran great. After sitting for. 4 hours fuel pressure issues started again, and check engine light came on.
- 2000c70hpt
Still lost tcm and a code for the little bulb in the antenna
Edit: After serious testing today I regained comm with the car. Though the tcm had to be disconnected. All wires check out, fuses good, I’m at a loss. It’s really starting to look like a tcm. Does anyone know if a used one with a software update will work? Or do I have to use a new one.
- 1257 Views
Last post by ggleavitt
- 2089 Views
Last post by PeteB
- 1832 Views
Last post by hethaerto
- 1315 Views
Last post by volvolugnut
- 55 Replies
- 22109 Views
Last post by andrewgabler
