I have a 2004 xc70, in the last month or so I’ve noticed a sort of whining noise accompanied by a very slight vibration I can feel in my steering wheel.
This noise seems to change with the RPM of the car but is most noticeable below 2000rpm. Maybe at higher revs I just can’t hear it anymore over the road and engine noise.
It’s not really a problem but I want to make sure it’s not a symptom of something failing.
My first guess would be something related to the power steering, but before I go replacing belts and bearings, I wanted to check with you all and see if you have any ideas.
Whining noise And slight vibration , changes with RPM
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
if you suspect the steering pump, try removing the serpentine belt and see if it stops. process of elimination. Is your upper engine mount tight?
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
You might try spraying the different pulleys with a water spritz bottle, like a windex sprayer.
My serpentine tensioner pulley made noise before it failed and took the belt with it.
- ignatz
- Year and Model: 2006 S60 t5m
- Has thanked: 18 times
- Been thanked: 33 times
Years back on my 01 V70 I had a noise that seemed to sound like a power steering pump. I started changing the power steering fluid and the noise never got quieter. A couple of days later the alternator clutch assy grenaded and now I knew where the noise was coming from. Sure seemed like it was a power steering pump, but it wasn't.
2002 V70 2.4
2005 S60 2.5t awd
2006 S60 t5 stick shift
2005 S60 2.5t awd
- Has thanked: 1611 times
- Been thanked: 4072 times
SwmBo E83 developed crickets in her PS; it took about 3 changes and time before the crickets croaked. It got a bit better each time.
