ive cracked my sump (oil pan) taking a shortcut to the mountains and hit a large stone on the road at speed.
has anyone changed their pan out, i spoke to the Volvo dealer and he said he sold many pans its very common.
My question is the little oil valve seated near the oil filter, how do i test it? i have two and ive sprayed some carby cleaner on both and the solvent passes through, the valve looks closed on both valves. are they both defective or normal??
No problems as far as warning lights or codes before my accident
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
I had a question about that little bugger also. Jimmy57 answered it in a thread I had a year or so ago. Let me dig it up.
See below. Take a good look at your oil pickup tube and it’s screen while you’re in there. There is an updated version which has a bellmouth shape to it which allows particulates to fall out of the bell to the bottom of the oil pan vs being “trapped” in there like the original metal pickup tube.
viewtopic.php?f=9&t=87109&start=20
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- darrylrobert
thanks for that, the pickup kinda looks like a bell, not sure do you have reference pictures?. there where a few little pieces of crude stuck to the pick up but alot less than i was expecting.
- - Pete -
The original one will be metal & stained brown from oil exposure. The updated one is plastic & black in color.
viewtopic.php?f=9&t=90563&hilit=pickup+tube
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
New pickup tube only matters if you are cornering very hard. Otherwise, old metal tube will live forever.
It is also possible to TIG weld the cracked pan, that can be cheaper.
jamadams11
- Year and Model: 2004 XC90
easy job, I got a replacement pan at the Pull a Part. get a seal kit.
- darrylrobert
thanks, i asked tow truck driver/mechanic if he could weld fix the pan and he said "NO" its an alloy it cannot be welded. Maybe i should have said TIG welding he probably does conventional welding...
Anyway i got a tow (200kms) back home and have my replacement pan cleaned up waiting for the new seals and sealant from Volvo parts.
jamadams
- Year and Model: 2004 S60, 2001 S60
- Been thanked: 3 times
you can weld the pan, if it is just cracked. But, the pan MUST be removed from the engine, completely cleaned first. there are tools/techniques to weld aluminum.
Please don't attempt to weld the pan while on the car.
- 1178 Views
Last post by theWIFES_S70
- 11 Replies
- 1287 Views
Last post by vtl
- 19 Replies
- 3008 Views
- 1030 Views
Last post by Bklein77
- 1373 Views
Last post by crussell83
