Bought an $800 XC90 - is it worth fixing? Could be fun
800DollarXC90
Year and Model: 2004 XC90
Post by 800DollarXC90 »
On April 11, 2020, I purchased a 2004 Volvo XC90 AWD 2.9 B6294T (T6) as-is for $900 after dealership fees. The XC90 was a former auction car. There were some electrical issues I noticed during my test drive, but the car was in great condition given the price. I decided to purchase, have my mechanic inspect, and it's been my daily driver since. To date, the only work I've put into the car is an oil change, a new engine filter, and a new set of windshield wipers.
Here's a list of the car's issues I was aware of before purchasing:
  • TIME FOR REGULAR MAINTENANCE
    ANTI-SKID SERVICE REQUIRED
    BULB FAILURE MULTIPLE BULBS
    ENGINE SYSTEM SERVICE REQUIRED
    TRANSMISSION SERVICE REQUIRED
    BRAKE FAILURE STOP SAFELY
Dash lights on:
  • ABS
    BRAKE
    CHECK ENGINE
    Red triangle with exclamation in the center of dash
[*]After a few minutes of driving, a message reading "BRAKE FAILURE STOP SAFELY" appears, and the temperature, RPM , and speedometer gauges die. The odometer stops rolling as well. When this happens, acceleration power goes in and out, the car jitters and glitches, and the transmission shifts rough for a few seconds, then driving is back to normal. However, the dash doesn't start working again - BRAKE FAILURE STOP SAFELY never goes away, and the aforementioned guages do not come back on. Note: I've driven a couple thousand miles since purchasing in March, and the odometer has only tracked >100.
Other issues:
  • Driver window doesn't roll down
    Driver door doesn't lock
    Driver side mirror doesn't adjust
    Seat warmers don't work
    Entertainment screen doesn't turn on, but radio stations, volume, and buttons work.
    Stereo speakers pop whenever the radio is turned on.
    AC/Heat don't blow very hard, and AC isn't cold unless I drive fast. Smells weird.
    Gas tank sometimes locks, sometimes doesn't. Always unlocks.
    The "W" button doesn't seem to work.
    Cruise Control doesn't work after "BRAKE FAILURE STOP SAFELY" comes up.
    Sunroof shade won't move, is stuck open.
    Sunroof makes a very loud grunting/crackling noise when I open it.
    Sometimes oil pressure light comes on, then goes off after I restart.
    Sometimes "COOLANT LOW STOP ENGINE" comes on, I'm thinking there's a leak.
    Trunk battery, and battery area, is extremely corroded, but have never had problems.
My mechanic checked the car out for me. Told me it's a great daily driver, but keep it in a 50-mile radius from home. Of course, I've taken it on a couple road trips already. Car doesn't die ever, but I need to start looking into these issues before more arise. My mechanic also recommends I see a Volvo electrician by the end of summer to look at my computer system - but I'm not quite sure if that means I need the system replaced or refreshed. Here are a list of codes my mechanic wrote down for me. Some of the descriptions may be misspelled or way off as I try and decipher his handwriting.
Engine:
  • 9282 - Control Module Problem
    E000 - Control Mode Comm
    9400 - Brake Pedal Sensor
    2910 - F. Heated 02 B2
    720A - Immobilizer
    261A - Long Term Fuel Trim
    4024 - Leak Dia Init Tank (Pump)
    4007 - EVAP
    E003 - Configuration Fault
Transmission: (Note: YOUR SENSOR)
  • 0092 - Solaroid Park / Natural Position Switch
    E000 - Control module
ABS:
  • 0094 - Comm
    0100 - Comm
    0114 - Comm
    0100 - Comm
SRS:
  • E003 - Comm
    00D5
His Notes of the car's general issues:
  • Caster/Cluster(?) Purg Valve
    02 Sensor B25
    Leak Diag(?) Unit in tank
    Brake Pedal Sensor
    Trans Control Module
    Diff El Module
    Central EL Module
    Your Pote/Date(?) Sensor
    R.F axel seal
    Rear Brakes
    L.F. Axel
    F. Tires
    L.F. Door Module
    Motor mounts
    Front struts
    Front links (?)
I'm not sure what these codes mean. Does a code mean it can be refreshed, or does this mean a part needs to be replaced?
Anyway, I'm a total dummy with cars, but am hoping to learn some stuff along the way as I fix up this guy. I'm not exactly sure of where I should start, though. Any tips? What do you think of this list? Thanks so much!
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
Always start with no parts required repairs. For you - start with your CEM. Look up water egress issues as some of your problems may be connection issues caused by water intrusion.
Also check the yaw sensor under the front passenger seat for water intrusion.
Check all of your vacuum hoses and plastic tubing for leaks, cracks, clamps or rotted rubber tubes.
There is also an on board diagnostic built into the car which will tell you what systems are not communicating - with this information you can back track and make sure your connections are not damaged. Do some searching and you will find a video and write ups on this feature.
Check your fluid levels: oil, transmission, brake and power steering.
Those are the free items.
The XC90 is not known for electrical issues unless something went wrong - like water intrusion.
gregdianec
Post by gregdianec »
Key sticks in ign. at shut down, sometimes trans sticks in park at start. Can sometimes pumping brakes will release this.
gregdianec
Help
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
gregdianec wrote: 02 Dec 2020, 11:36 Key sticks in ign. at shut down, sometimes trans sticks in park at start. Can sometimes pumping brakes will release this.
Could be the Ignition Lock Cylinder issue. More here https://www.matthewsvolvosite.com/forum ... 72#p351472
eapowers64
Year and Model: 2004 xc90
Has thanked: 2 times
Post by eapowers64 »
You need to sign up to receive alerts from a local/regional pull-a-part or other self-service junkyard. The 04-06 six cylinder is notable for it's overmatched transmission. Thus, you get a lot of decent cars showing up in junkyards because of bad transmissions that would require costly repair. I bought an 04 for $750 and have replaced every audio component, seats, lots of interior bits, etc from a continual supply of junked cars. You also get to experiment on how to disassemble on a car other than your own.
