Can anyone tell me what these Torx screws are and where I can get replacements? FCP Euro wasn't sure....
I'm guessing M5, but not 100% sure...it is definitely NOT an M6. I lost one a while back (it disappeared down into the recesses of the front body somewhere), and I really don''t like having this pipe not secured properly.
Thanks!
Jonboy
02 V70 2.4T - Screws that hold the Charge Air Pipe in place?
- Has thanked: 987 times
- Been thanked: 1075 times
I suggest going to someplace like Ace Hardware and buying several metric screws you think might fit. I do know they are different sizes for the two places. Keep in mind metric screws have about four thread pitches. The head size and type don't matter. You might even be able to return screws you don't need.
EngineeringBloke
- Year and Model: 2006 2.5T S60
- Has thanked: 57 times
- Been thanked: 39 times
Take one to Lowes, they have a display in the nuts and bolts section that you can thread bolts into to check the size. Don't force it or you could damage your bolt.
It looks like flange screw 11 or 20, depending on which charge air pipe you have
They show as M6 x16 mm hex heads on the Volvo diagram, btw
Hmmmm, mystery.
Maybe pull that other one off and take it to Lowe’s to match.
Hmmmm, mystery.
- RickHaleParker
- Been thanked: 978 times
There are lots of them screws around the car. Take one from another location to determine the thread size. Then go find a replacement at a hardware store.Jonboy74 wrote: 06 Jun 2020, 16:19 Can anyone tell me what these Torx screws are and where I can get replacements? FCP Euro wasn't sure....
Active
Past
Past
- Been thanked: 504 times
I just removed the bolt and measured it for you.
It is M5 x 1.0 mm x 20 mm (length).
Either Ace hardware store or local junk yard should have it.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
That's a junkyard part for me. I try to grab a couple when I go. Easy to lose.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
You can use the Volvo web store and grab the part number, then use the fitment tab and Sometimes find a non-critical place the same fastener is used in the car, too!
- 9387 Views
Last post by Rattnalle
- 5023 Views
Last post by kallekula
- 18 Replies
- 7711 Views
Last post by Rollvo
- 1136 Views
Last post by Oitsujosh
- 5137 Views
Last post by darrylrobert
