98 XC:all electronics shut off while driving
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
This past Saturday (6/6), I left my car running for 4 hours with AC on for my dog while I went through the junk yard looting a 98 V70 glt and 99 s70 t5. I finally headed home with AC still on. About 25 miles down the road, I showed down to take the clover leaf to the next road. when I slowed down mostly, all electronics shut off and immediately turned back on. About 2 miles down the road it happened again but for about 1 second. then today (6/8) I was headed out to parents house and the electronics shut off for about 5 secs. I was unable to use gas, lights were off. I have a power steering and oil leak. I'm questioning if I should have spent that money on another car instead of on more parts for this car and other stuff. please help me ASAP.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
- Has thanked: 311 times
- Been thanked: 817 times
Sounds much like the electrical part of the ignition switch is going bad, which is very common. Basically all of the factory ones have failed or will soon. Test by jiggling the key or by easing the key back and forth, while idling. Has it ever been replaced? Did you grab one from the junker?
- Has thanked: 2200 times
Also check the B+ cable up in the kidney shaped main fuse box. The are bad for melting and hide it well where they come into the bottom side of the box. Not a 100% surefire clue is the nut and cable end will oxidise.
- CIK7
does this mean the ignition needs to be replaced? which part needs to be replaced?erikv11 wrote: 08 Jun 2020, 19:23 Sounds much like the electrical part of the ignition switch is going bad, which is very common. Basically all of the factory ones have failed or will soon. Test by jiggling the key or by easing the key back and forth, while idling. Has it ever been replaced? Did you grab one from the junker?
Just the electrical portion not the whole thing, it's an easy job. This is the part for your 98 V70: https://www.fcpeuro.com/products/volvo- ... 90-9447804
Only use the Volvo branded part for this. Pulling one from the junkyard is reasonable to assume it is working now, but realize it could go bad again. If you're looking for one at the junkyard, note carefully which cars have the asme one. They are listed on the "fitment" tab of that link at FCP.
How to replace it: viewtopic.php?f=1&t=55868
Remember we are not certain it's the electrical portion of the ignition switch, but it is a good chance. Worth doing some troubleshooting.
- CIK7
thank you. I have an identical junk car and will put that ignition piece on there.erikv11 wrote: 08 Jun 2020, 22:56 Just the electrical portion not the whole thing, it's an easy job. This is the part for your 98 V70: https://www.fcpeuro.com/products/volvo- ... 90-9447804
- CIK7
thank you I will take a look.scot850 wrote: 08 Jun 2020, 19:30 Also check the B+ cable up in the kidney shaped main fuse box. The are bad for melting and hide it well where they come into the bottom side of the box. Not a 100% surefire clue is the nut and cable end will oxidise.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
In what shape is a battery?
You will need to perform a voltage drop test and aternator output when everything is warmed up(after about 30min.of driving),without turning the engine off.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- CIK7
the battery is brand new. I hope it's not that.misha wrote: 09 Jun 2020, 13:03 In what shape is a battery?
- 19 Replies
- 5289 Views
Last post by Eliotlm
- 34 Replies
- 2896 Views
Last post by jonesg
- 1554 Views
Last post by RickHaleParker
- 2164 Views
Last post by BEJinFbk
- 2083 Views
Last post by RLBOHNER38
