S60 Starter Solenoid Connector
s_watts
Year and Model: 2006 S60
Post by s_watts »
Hello,
My 06 S60 2.5T has had infrequent problems starting that have become more frequent. I identified the issue as the starting solenoid connector, took it off and cleaned in well. That solved the problem but its quite the regular occurrence now.
I took it to the shop and of course it had no issues. As it was the turbo model they said as long i should leave it as is. Next day it wouldn't start again. I called one volvo dealership and they werent to helpful.
So I'd like to fix it myself if possible. Is it possible without taking the turbo tubes off. I am having trouble identify what part no's or connector is required. Does anyone have any experience permanently fixing this on a turbo model?
Thanks!
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
are you trying to replace the starter power cable? or is it the starter itself that has gone bad.
s_watts
Post by s_watts »
I just want to replace the cable. The starter was replaced a couple years ago with a bosch starter. When the connection is good the starter is very strong.
jonesg
Post by jonesg »
s_watts wrote: 11 Jun 2020, 11:09 I just want to replace the cable. The starter was replaced a couple years ago with a bosch starter. When the connection is good the starter is very strong.
The small wire, have you tried using deOxit spray and squeezing the plug to get better contact.
s_watts
Post by s_watts »
Yes, that is what I have done to get it to work much better. It was quite effective but now does not last as long, I'm not sure if the connection is the only issue.
jonesg
Post by jonesg »
could be ignition switch, not the lock part but the elec part of the switch.
On my old 740 I looked at the price of a new switch and installed a momentary push button.
Turn ignition to pos II and press the button, button was wired to the small terminal of starter solenoid with an inline fuse.
It picked up 12v from the cig lighter socket.
