engine serial number where is it
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
My sticker has long ago unstuck itself from the timing cover, i want to check i have fitted the correct timing belt and tensioner kit. I cannot find info on VIDA, my registration papers have a engine number but it has too many numbers and letters in it. I looked on the engine block but cannot see anything where VIDA says it should be.
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
Has thanked: 1609 times
Been thanked: 4065 times
You have to remove the exhaust cover plate and look on a shelf right behind the exhaust cam side of the cylinder head, and clean it with a paper towel and gunk remover
Right “behind” to the left side of the water pipe
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
Its like the crank timing mark, you can't see it with both eyes and only the first 2 numbers are accessible.
And thats if you know exactly where its located and get it cleaned enough to read.
Photo above is probably from a boroscope.
I reached in with my cellphone and took a dozen photos, finally got it after scrubbing the shelf with a toothbrush and brakecleen.
I need to swap the steering rack too, should have just pulled the engine and made everything easier.
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
Active
Past
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
abscate wrote: 13 Jun 2020, 04:57 You have to remove the exhaust cover plate and look on a shelf right behind the exhaust cam side of the cylinder head, and clean it with a paper towel and gunk remover
I wish mine was looking this good 8)
On P2 cars Volvo hired an old lady to stamp the blocks
