Bars Leak Head Gasket Sealer
Faust
- Year and Model: xc70 2008
- Has thanked: 31 times
- Been thanked: 10 times
RE: '04 V70 NA. I just wanted to report and I guess endorse Bars Leak "Professional". Although I don't know the size of the leak, I guess I had a pretty good hole in my head gasket. Plenty of steam out of the overflow bottle and enough pressure built up to blow off the top radiator hose. In any case I decided to give the $50.00 Bars Leak "professional" a try. After a pleasant call to Bars Leak question line, I flushed it and followed the directions. I have to report success. I am only 4 days into it, but all seems fine. I haven't tried highway speed yet, because package indicates several cycles of heating and cooling aid it. I will report if it fails. They have several less expensive head gasket products, but I didn't try them
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
AnotherVolvoNewbie
- Year and Model: 2000 V70
Any update? I’m about to try this out today or tomorrow
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
In my opinion, a resurfacing of the head + block and a new gasket should fix the issue. My radiator exploded, the hose didn't come off, it exploded because of a bad HG. I also had 0.002-0.0027 thou block warpage but did not take care of it. I hope it doesnt bite me in the ass.
- Been thanked: 4068 times
Look at his user name. It’s possible this will work, but you may have to make a deal with unpleasant parties to succeedAnotherVolvoNewbie wrote: 11 Apr 2024, 10:50 Any update? I’m about to try this out today or tomorrow
Faust
The car is now long gone, but sealer lasted for the 6 months further that I owned the car. Had a similar problem on the Volvo that I replaced it with, and the sealer managed to stop up the heater core, leaving me without heat. Ignore Abscate's comment, there is nothing worse than an amateur humorist.
2004 V70
dikidera
And on the other forums they tell me Volvos dont get bad headgasketsFaust wrote: 13 Apr 2024, 06:50 The car is now long gone, but sealer lasted for the 6 months further that I owned the car. Had a similar problem on the Volvo that I replaced it with, and the sealer managed to stop up the heater core, leaving me without heat. Ignore Abscate's comment, there is nothing worse than an amateur humorist.
