Hi guys,
I need to change my tank, whose P/N is 8693773, the one with high pressure washer.
Since the high pressure washer pump is a block of rust, broken in two pieces, I never used it, so I was wondering if the tank without pressure washer, P/N 30655661 is a good fit too, in terms of shape.
If this is the case I would expect the same without the hole for the high pressure pump.
Am I correct?
Thank you,
Alex
Winshield washer tank
- 689 Views
- 15 Replies
- 8781 Views
Last post by volvolugnut
- 36 Replies
- 24789 Views
Last post by StickyPocket
- 404 Views
Last post by ggleavitt
- 2193 Views
Last post by kdaide
