Hi. Sir/Madam
My car: 1995 850SE station wagon.
My ECU not get proper temperature value from my temp sensor, it always shows about 70°C event a brand new sensor installed, so ECU never send coolant fan "on" signal to coolant fan controller 1398845.
I'm trying to create a new fan controller logic system by using Davies Craig 0401 mechanical thermatic switch plus a 40A relay to control my coolant fan.
My problem is: I can't find +12V power supply in Engine bay under ignition on position to set up a fan controller to let the coolant only works on key on. As result, I have to use the batter +12V instead, this will make the coolant fan drain out battery some time.
Any one have any idea, please advise!
Ignition on 12v power in Engine bay
- Has thanked: 311 times
- Been thanked: 817 times
You can use the yellow accessory connector under the dash. I haven't done it myself but there are a couple grommets in the firewall you can use to pass a wire from there to the engine bay.
There are definitely fuse box options, good thinking. Glad you got that part sorted.
- 1086 Views
Last post by CIK7
- 2906 Views
Last post by 93SCMax
- 1778 Views
Last post by BEJinFbk
- 15 Replies
- 8096 Views
Last post by PatrickHenry
- 12 Replies
- 4743 Views
Last post by DrDan
