Did you know? 🤔
Ignition on 12v power in Engine bay
cidylong
Year and Model: 1995-850SE
Has thanked: 0
Been thanked: 0
Australia
cidylong
Post by cidylong » Tue Jun 16, 2020 2:43 am
Hi. Sir/Madam
My car: 1995 850SE station wagon.
My ECU not get proper temperature value from my temp sensor, it always shows about 70°C event a brand new sensor installed, so ECU never send coolant fan "on" signal to coolant fan controller 1398845.
I'm trying to create a new fan controller logic system by using Davies Craig 0401 mechanical thermatic switch plus a 40A relay to control my coolant fan.
My problem is: I can't find +12V power supply in Engine bay under ignition on position to set up a fan controller to let the coolant only works on key on. As result, I have to use the batter +12V instead, this will make the coolant fan drain out battery some time.
Any one have any idea, please advise!
Has thanked: 99 times
Been thanked: 293 times
United States of America
Re: Ignition on 12v power in Engine bay
Post by erikv11 » Tue Jun 16, 2020 11:37 am
You can use the yellow accessory connector under the dash. I haven't done it myself but there are a couple grommets in the firewall you can use to pass a wire from there to the engine bay.
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 286k
'06 S60 R, 167k
'99 Camry V6 :shock: 125k
cidylong
Has thanked: 0
Been thanked: 0
Australia
cidylong
Post by cidylong » Wed Jun 17, 2020 1:59 am
The ignition +12v found in my fuse board, number 4.
Tested, works fine.
Post by erikv11 » Wed Jun 17, 2020 7:53 am
There are definitely fuse box options, good thinking. Glad you got that part sorted.
'96 855 NA, 145k
'06 S60 R, 167k
