98 XC: VERY bad starting sound after replacing injector seals
CIK7
Year and Model: 2026 Sportrailer GLT
Has thanked: 350 times
Been thanked: 108 times
Post by CIK7 »
I removed my injectors to change filters and seals and just now got it back together and tried to start it. at first it started and was idling at about Eleven hundred RPMs before working down but it didn't sound like it was idling at 1100 but maybe 600 or so. so I shut it off and restarted it and the engine knocked and there's banging so I shut it off. now everytime I try to start it there's big banging going on.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
Has thanked: 2197 times
Been thanked: 1850 times
Did you drop anything down an injector port by chance? Did one of the pintel rings fall off the injectors?
I would suggest that you go back over what you did. As a wise man once said to me, if the issue wasn't there before you started then it was something you did.
Is the banging a mechanical noise or a back firing type noise?
CIK7
Post by CIK7 »
scot850 wrote: 16 Jun 2020, 17:25 Did you drop anything down an injector port by chance? Did one of the pintel rings fall off the injectors?
I didn't drop anything down the ports. I even looked. I found that one of the fuel injectors wasn't working and swapped it for new one. I tried starting again and I think the first start damaged a piston or something because it sounds bad. what happens when one fuel injector doesn't work? does it get the piston messed up?
CIK7
Post by CIK7 »
now my car won't start
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Did you do ANY other work when you changed injectors/seals? What else did you remove, if anything, to gain access to injectors?
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
can you make and post a video/audio? Recheck all your connectors. try disconnecting the leads one at a time, and see if you can determine a problem.
Current Volvos:
CIK7
Post by CIK7 »
volvolugnut wrote: 16 Jun 2020, 18:49 Did you do ANY other work when you changed injectors/seals? What else did you remove, if anything, to gain access to injectors?
no other work. if a fuel injector is unable to inject fuel, that means the piston won't be able to be powered to move. can this break crankshaft or piston parts? I'm hoping not. I'm prepping for that scenario by shopping for another volvo.
CIK7
Post by CIK7 »
FLXC90 wrote: 16 Jun 2020, 19:25 can you make and post a video/audio? Recheck all your connectors. try disconnecting the leads one at a time, and see if you can determine a problem.
got an XC90 player on here, eh? welcome! well I think my battery is totally dead. tried jumping it too and didn't work.
The car should still start if an injector is bad and not working. Car will run rough. Try removing the spark plugs and see if any of the cylinders is full if fuel. If one is leaking you may have hydro-locked the engine.
Has thanked: 1609 times
Been thanked: 4064 times
Don’t sweat, you haven’t broken anything serious. Rough running sounds like Hades sometimes.
