Did you know? 🤔
98 XC: VERY bad starting sound after replacing injector seals
CIK7
Year and Model: 1998 Volvo V70 XC
Has thanked: 68 times
Been thanked: 3 times
United States of America
CIK7
Post by CIK7 » Tue Jun 16, 2020 4:59 pm
I removed my injectors to change filters and seals and just now got it back together and tried to start it. at first it started and was idling at about Eleven hundred RPMs before working down but it didn't sound like it was idling at 1100 but maybe 600 or so. so I shut it off and restarted it and the engine knocked and there's banging so I shut it off. now everytime I try to start it there's big banging going on.
1998 V70 XC black ($1K trade, Mi:143,995/151K, immaculate engine, totalled 5/2/20)
1998 V70 XC white ($50 cash, junk, donor for my black XC)
2001 V70 Ba white (sold)
2009 Impala LT 3.5L (sold)
Plans for my 98 XC: 16T/18T, P2 M66 swap, logo/badge delete excl grille
Has thanked: 12 times
Been thanked: 230 times
Canada
Re: 98 XC: VERY bad starting sound after replacing injector seals
Post by scot850 » Tue Jun 16, 2020 5:25 pm
Did you drop anything down an injector port by chance? Did one of the pintel rings fall off the injectors?
I would suggest that you go back over what you did. As a wise man once said to me, if the issue wasn't there before you started then it was something you did.
Is the banging a mechanical noise or a back firing type noise?
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
CIK7
CIK7
Post by CIK7 » Tue Jun 16, 2020 5:50 pm
I didn't drop anything down the ports. I even looked. I found that one of the fuel injectors wasn't working and swapped it for new one. I tried starting again and I think the first start damaged a piston or something because it sounds bad. what happens when one fuel injector doesn't work? does it get the piston messed up?
CIK7
CIK7
Post by CIK7 » Tue Jun 16, 2020 6:26 pm
now my car won't start
Year and Model: 2001 V70
Has thanked: 35 times
Been thanked: 75 times
Post by volvolugnut » Tue Jun 16, 2020 6:49 pm
Did you do ANY other work when you changed injectors/seals? What else did you remove, if anything, to gain access to injectors?
2001 V70 T5, 1986 244DL, 1983 245DL, 1975 245DL, 1959 PV544, multiple parts cars.
FLXC90
Year and Model: 98 V70 T5
Has thanked: 2 times
Been thanked: 17 times
FLXC90
Post by FLXC90 » Tue Jun 16, 2020 7:25 pm
can you make and post a video/audio? Recheck all your connectors. try disconnecting the leads one at a time, and see if you can determine a problem.
Current Volvos:
CIK7
CIK7
Post by CIK7 » Tue Jun 16, 2020 7:43 pm
no other work. if a fuel injector is unable to inject fuel, that means the piston won't be able to be powered to move. can this break crankshaft or piston parts? I'm hoping not. I'm prepping for that scenario by shopping for another volvo.
CIK7
CIK7
Post by CIK7 » Tue Jun 16, 2020 7:45 pm
got an XC90 player on here, eh? welcome! well I think my battery is totally dead. tried jumping it too and didn't work.
Canada
Post by scot850 » Tue Jun 16, 2020 11:28 pm
The car should still start if an injector is bad and not working. Car will run rough. Try removing the spark plugs and see if any of the cylinders is full if fuel. If one is leaking you may have hydro-locked the engine.
2006 XC70
Has thanked: 333 times
Been thanked: 1035 times
Trinidad & Tobago
Post by abscate » Wed Jun 17, 2020 4:16 am
Don’t sweat, you haven’t broken anything serious. Rough running sounds like Hades sometimes.
Link To Volvo Glossary
